Results 1 to 8 of 8
Thread: Advice on removing the front grille badge (facelift)
    Regular Member Envy's Avatar
    Welwyn Garden City
    Vehicle : Vectra C
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Advice on removing the front grille badge (facelift)
    Evening all
    I have removed the front Chrome V and have started to sand this down so it can eventually be colour coded to the car.
    Im a bit stuck on how to remove the front badge from the V.
    I see four clips which I can pop out but the badge wont budge and I dont want to force it.
    Could someone maybe let me know what im missing
    Many thanks
    Regular Member Wolflinn's Avatar
    Feb 2010
    Camberley
    That clip in the middle between the 2 bottom red dots, and the 4 red dots will release the back plate, that the badge clips into.
    It is stiff to get out and fragile, you just have to be gentle and forceful.
    Or
    The badge will remove without taking the backing plate off by releasing the silver clips around the center dome and pushing a thin point through each small hole at the back off the dome to ease it out, again gently
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    How did you get the chrome of the grill?
    Welwyn Garden City
    Vehicle : Vectra C
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for that Wolflinn. That really helps.
    Naill83 - I have started to use 120 Corse wet and dry. Im leaving it quite rough so the primer will take to it. It looks like scratched stainless steel now.
    Its very slow going but all in all has taken me about 1.5 hours of sanding so far. Just need to finish off some small areas once the badge is off
    Jun 2011
    Newcastle
    Pics!!! I wanna see pics! Thinking about taking the front badge off myself. I can see a little bit on your avatar but not big enough.
    Aug 2011
    Kilwinning
    Hi there how did u manage to get the chrome v off??
    Sep 2010
    Dumfries, Scotland
    I think you'll also need to scrape away all the little dimples in the middle. They're pins that come through the black plastic part from the griffin. The griffin and the chrome ring are bigger than the hole in the chrome V, so if you don't take the griffin off, yu can't take the black plastic part away from the V, if that makes sense!!
    Welwyn Garden City
    Vehicle : Vectra C
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by Chaz114 View Post
    Hi
    I remove the front bumper and placed a small flat head screw driver bit under each clip that held on the v. Once I edge all of the bits in I then slowly slid the front V out. Just take your time with it and you wont break any clips.
    Also getting the badge off was a right pain in the rear. The little dimples/pins you see in one of my pics (Back of the badge) were glued in. I scrapped away all excess glue but then had to use a very small posi driver to push the pins which attach to the griffin badge out.
    I rushed it and broke a few as I was getting a bit upset with it. Hmmm. Anyhow it finaly came away. Once everything was painted I used araldite to glue all back together again. Hasn't moved since.
  1. For Sale: Pre-facelift Irmscher Grille (with red silhouette badge)
    By dae36 in forum Parts for sale
    Last Post: 2nd January 2013, 14:11
  2. Facelift grille badge
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2011, 16:34
  3. Need help/advice asap! Grille badge!
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:44
