Thread: Vec C rear pads and disc change
    Jul 2011
    Guildford
    Default Vec C rear pads and disc change
    Hi guys, I have been out all day yesterday replacing the rear discs and pads on my 2005 Vec C 1.9cdti, after i put it all back together I did the correct thing by pumping the brake pedal first then applying the handbrake, to allow for auto adjustment, but the pedal keeps pumping up and the brakes feel really pants, I have taken it for a long drive and when i stopped i noticed that the pads were only contacting on the outside of the disc, approx half a pads width worth, when i changed the pads i wound them in after removing the res cap, but i didnt clamp off the flexi pipe and undo the nipple as i only found out about this AFTER i did it my way!!!! I have been searching the internet and some people are saying the Vec Cs master cylinder seals CANT flip as they are doubled up some say they can be????!!!!!! its all very confusing, and why is the rear brake pads only contacting half a pads width? The car has run out of MOT now so its difficult to drive around to bed the pads in, by the way i also replaced the anti rattle springs as i know on my old Vec B sri if these were misshapen in any way it can cause the caliper to sit incorrectly and pull the pistons further back............
    Devon
    Quote Originally Posted by bigtaf View Post
    I didn't clamp my hoses and my brakes were fine after changing the pads the and discs.
    Not sure what you mean about the pads only contacting the discs half a pads width, but if this the case you've either got the wrong pads fitted or you have not fitted something correctly. I would dismantle and check everything you have done. In particular check that the discs have been fitted flush to the hub - you need to give the hubs a good clean with a wire brush to get rid of all the dirt and rust.
    Also compare what you have fitted with what you have taken off to make sure it's the same!
    Regular Member Jezzy's Avatar
    S.E
    I know exactly what you mean about the full pad not contacting the disk, it's usually down to cheap pads not machined correctly or the pad bending when pushed by the piston; but you need a few miles under your belt before you can be sure, as they may just need to bed in. However, if after 100 or so miles it's still only half the pad touching the disk, then change the pads asap - if it goes on too long then the disk will need to be changed as well, as it won't be flat any more.
    Jul 2011
    Guildford
    Will keep trying to bed them in then, im assuming thats the cause of my pedal pumping up and poor footbrake and handbrake efficiency too?
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Its a while since i did the rears on mine,but i recall that you had to release the self adjusting rod under the handbrake lever for them to adjust properly, after failing MOT on rear brakes I discovered that the plastic lock tab had broken, may be worth checking that area is ok.
    HTH
    Jul 2011
    Guildford
    cheers all, im not sure where this self adjusting rod is but i will do a bit more research and see how to adjust
    Regular Member Keif's Avatar
    In the Garage
    Check out the How To on replacing the handbrake cable, there are photos of the lock tab on their.
    Regular Member sla002's Avatar
    hayes, middlesex
    did my pads only, on wednesday. thursday afternoon noticed i had the very same problem. spent yesterday driving around with the handbrake on, to try and wear them into the surface a the discs. today stripped them again and it looks like slowly but shorly the pads are making contact with more of the disc. cleaned and greased them again, refitted and will be keeping an eye on them for the next 40/50 miles. just a badly manufactured set of pads i recon.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    done all my discs and pads a week ago using mintex sets, did not release bleed nipple or clamp off pipe, brakes feel good apart from a very sligt squeek on front off side disc every now and again
  1. How to on disc & pads change
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2013, 23:03
  2. Rear Disc corrosion - `cheapo' Vx versus Vx`OEM' pads
    By omega2498 in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2010, 18:21
  3. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  4. New Disc & Pads
    By AJA in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2006, 11:46
  5. rear disc pads Vectra C
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2006, 21:48
