Results 1 to 10 of 11
Thread: Doggy brake pads?
    Regular Member sla002's Avatar
    hayes, middlesex
    Default Doggy brake pads?
    hi guys,
    brought some new mintex rear pads for my cdti150. fitted them to the car wednesday and everything seemed ok. thursday went out in the car and the rear pads are squealing.
    when i got home i checked them and the pads only seem to be making contact with half the disc surface.
    when i fitted them i took the top and bottom edges off as you do when fitting new pads to used discs and put copper grease on them.
    so i stripped them down again and the top and bottom of the pads aren't touching the lips on the discs so its not that and the grease is in all the right places but there still squealing for about the first 2/3 miles when cold and there not making full contact with the discs.
    checked the calipers aswell and they move as they should and aren't sticking/binding.
    discs surface seems smooth and the old pads where worn evenly.
    been driving around with the handbrake on today to try and wear the pads into the discs seems to be working. but not sure if its the best way to sort the problem.
    any advise would be greatly received.
    cheers guys.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    "Doggy" brake pads? They're making them out of puppies now? Sheesh Vauxhall will do anything to save money...
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by Ian-Highlander View Post
    No wonder they are sqealing
    Regular Member Ben_'s Avatar
    Audiville, WM
    Sounds like they could be a wuff set maybe
    Sorry....sure someone can be a bit more sensible with answer.
    hayes, middlesex
    lol, i mit have known. saw it after i posted it but i can only edit the write up not the title, oh well spelling never was my stronge point.
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Are they jamming in the guide rails at all, sometimes a bit of corrosion can cause em to stick.
    hayes, middlesex
    cleaned them thoroughly when i charged them and copper greased them and its all 4 pads.
    i've had them appart again today and it seems that slowly but shorly more of the pad is coming into contact with the discs. maybe a slightly badly made set of pads.
    i'll keep monitoring them for the next 40/50 miles anyway. but its looking good.
    cheers though.
    scotland
    they will bed in mate !
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Had the same with a set not long ago. Some 'enthusiastic' braking helped them bed in nicely.
    Regular Member Craig1985's Avatar
    harwich essex
    I've always coated mine in copper grease, backs and sliders and never had a problem with squeeking? The squeek is often a vibration fron the pad due to brake dust. I don't rate those anti vibration pads they slick on them.
  1. Brake Pads
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 15:22
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. brake pads
    By HEP in forum Handling & Braking
    Last Post: 17th October 2008, 23:32
  4. EBC Brake Pads
    By andy13 in forum Parts for sale
    Last Post: 26th June 2008, 16:44
