Results 1 to 10 of 14
Thread: V X Arrrrggghhhh!
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    Default V X Arrrrggghhhh!
    Hi, good evening
    tomorrow is the vxr's big day taking us to belgium for the gp at spa
    a couple of queries!
    one is tyre pressures - the book says 42 front 38 rear, on checking i had 30 in the front and 27 and about 20 in the rear, i have put them up to 38 all round, will that be ok? i have read on here that there are different opinions on pressure vs tyre wear vs ride comfort - opinions welcome!
    the next thing,
    on they way up north to drop the kids off with the mother in law, i get these lights on the dash, traction control and shock light, did this 3 times, cleared twice by re starting and once it went by itself, any ideas??
    Glasgow
    Stick to what the book says or your more likely to crack an alloy. Heavy car - low profile xl rated tyres - fast car = High tyre pressures. With regards to the warning lights I wouldn't drive any great distance never mind Europe without getting it sorted.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i run 38 all round with no probs.. you should be fine,,, dunno about the warning lights though.. looks like and IDS fault
    Cambridgeshire
    thanks for the advice on the tyres
    the cdc fault is intermittant so ill have to put it in when i get back as we go at owl f4rt in the morning! typical!
    scottish region
    Does your rear brake lights work as i got they warning lights when my brake lights switch needed replaced
    spoons
    Guest
    42 psi front and 38 psi rear
    If you're using the 19" VXR alloys they will crack and buckle at any opportunity so I would maintain standard tyre pressures and remember to inflate them further if you have a full load.
    Have a good holiday and take loads of pictures
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Were you accelerating hard when the lights appeared?
    Cambridgeshire
    thanks guys, i will take pics and post on my return
    i was not accelerating hard when the lights come on, i did 260 miles and averaged 37.7 on the bc which i was quite pleased about!
    brake light bulbs are all there, funny you shoul say that though i have had to replace 2 brake light bulbs and a front side light bulb since ive owned it which is only around 6 weeks!
    Dec 2005
    In an estate car
    Could be the IDS sensor plugs on each shock...have a look behind each wheel and you'll see a plug near each shock unplug, clean and replug firmly. Hopefully it's just a loose connection.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Yes ids fault in my elite was the o/s/f hub sensor. As above check the plugs first
