Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Engine management warning light just come on, help please.
    Unhappy Engine management warning light just come on, help please.
    hi all , typical, had the car 3 days and the Engine management warning light has come on...The question i need answering is, do i have to take it to vx dealers only to have it read and cleared ..????
    cheers guys....micky.
    newport
    depending on the car, try foot on brake and acc pedal, then ignition to postion 2, eml light starts to flash out the codes. if you do a search on here for pedal test the how2 should tell you more. works for my 2003 1.8
    2.2i on a 57 plate, just tried and no joy, cheers anyway mate...
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    where are you AF
    plymouth bud
    Oct 2006
    southampton
    11 Post(s)
    being a 2.2 direct matey, good possibilty it could be code p1112, swirl flaps sticking, mines a 55 plate, 24,000 on the clock and had 2 replaced already, light is coming on again now, fitting a catch tank to eliminate the problem hopefully...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Catch tank and EGR blanking on the 2.2 should eliminate it completely. PS the 2.2 petrol can easily be blanked with no warning lamps.
    Oct 2006
    southampton
    11 Post(s)
    can i blank mine completely then Rushy...
    wots a "catch tank" and do i take it to vx to do ? i have a 12 month gold warranty with the RAC, would this be covered ?
    cheers guys.
    Oct 2006
    southampton
    11 Post(s)
    yes matey, they will replace the inlet manifold to though as its quicker to replace than clean out... they did that with mine...
    By Shadrack in forum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Engine Management Warning
    By C9_hardlatch in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2007, 16:12
