Results 1 to 10 of 21
Thread: Still got my EGR fault... Even with a replaced EGR.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Still got my EGR fault... Even with a replaced EGR.
    Hi guys.
    Still got the EGR problem with my car (2.2 DTi). It comes up with a code for insufficient flow through the EGR. The throttle body has been cleaned, the boost sensor was cleaned a few months ago but will be done again just to be sure, a different EGR has been fitted (and we know it's a good one) too but this didn't stop the car flicking into limp home mode when it's up to 60-70mph at around 2000 RPM and only has a light load on the engine. The next thing to change will be the boost sensor.
    Can anyone else think of what will be causing this? As far as I know, the EGR doesn't monitor the flow through it and it doesn't drop into LHM if you rag it or leave it in 4th on the motorway, so the other question is, what is the engine doing at 2000ish RPM with light load that it isn't happy about?
    Cheers.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you checked all the turbo hoses fella?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Checked the top ones, not the bottom ones. It is suspected that the intercooler has a slight split in it but it doesn't feel down on power and made 135hp on the rolling road on Saturday.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by cont1204 View Post
    Cheers.
    I think those are the RPM when the engine starts to pull stronger, so could well be a boost related problem (or vacuum).
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Celes View Post
    Hmm, the flaps on the inlet manifold work on vaccum don't they? Might got for a dig around later on and see what I can find. Just can't understand why if you cane it hard, it's fine and goes well, just if you cruise it isn't happy about it.
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    This is a problem I've had and keep getting on and off. I replaced my EGR with new, New boost sensor and all boost pipes as well, but it will still go into LHM once in a while at about the same Rpm and speed as you. Now looking into turbo calibration as i've had the actuator adjusted.
    Innes on here is the man when it comes to vacumm and boost problems. I'm sure he'll be on soon to assist.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Vectra Forever View Post
    Cheers. I've not fiddled with the boost so no idea if it's above or lower than what it should be.
    Hope so! Every time it's up to those speeds and on the odd ocassion, about 40mph, it's always in limp home mode! Almost makes driving on the motorway dangerous.
    Regular Member Innes's Avatar
    Plymouth
    I had this alot and it drove me crazy for a while.
    It could be one thing or a combination of things. It doesnt sound line an EGR problem. Have you read the codes since you put the new EGR on? Have you also read the codes with just the ignition on (postion II)? If not, try it. I code a code that wasnt stored when the engine was running and it related to a faulty Vacuum solenoid (error P1590 Vacuum Solenoid Valve Circuit Open). See my thread HERE. This turned out to be my main issue.
    The other options are:
    Split vacuum pipes. These tend to perrish on the rubber connectors but the engine cover can rub through them. They are best replaced with silicone hoses from ebay for £6. See my thread HERE.
    Boost Sensor. It can get gunked up as you know but you have to be careful cleaning it. It might need changing but you tend to get error code P0234 - Boost Pressure Control Circuit Negative Deviation. This error code could also indicate that the turbo Actuator rod needs a halft turn to adjust when the boost comes in.
    read the codes again with the igintion at postion II and with it running as well then post up your findings.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Have you tested the vacuum actuattors , If one of these goes faulty then you effectivrely have an open system
    and still loving it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Innes View Post
    Cheers dude. I'll check the rubber connections.
    Quote Originally Posted by bobssignum View Post
    Cheers, is there any way to test these or is it just a case of looking for a fault code?
  1. New fault codes after EGR replaced!!
    By lencuff in forum Y & Z30DT Specific
    Last Post: 5th December 2012, 21:09
  2. Swirl Flaps replaced, still got fault code!!
    By Casper85 in forum Engine & Drivetrain
    Last Post: 24th September 2012, 14:59
  3. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  4. Replies: 15
    Last Post: 9th July 2011, 22:19
  5. any one replaced the ecu?
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2011, 23:44
