Thread: ndcd 2013 removal
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    Default ndcd 2013 removal
    Good morning..
    I have found that my sat nav disc drive doesnt seem to read any discs, i am going to assume the laser is dirty at this point.
    Is it just straight forward to remove the radio unit and unplug it, clean it and put it back?
    i do have the radio code..i have read about tech2'ing this thing and pairing and depairing..surely it wouldnt be as much hassel if the car battery died which will be a similar situation!
    Russ
    milton keynes
    yes , no codes are required to be inputted for a ncdc after power loss.
    Aug 2011
    West Malling, Kent
    mmmm..its a ****** trying to get that head unit out....anyone got any hints lol?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Double din puller keys (about three quid from Halfords) and if it still wont come out, pull the silver strip off that goes above the glovebox and under the centre vents, then four torx bolts to release the centre vents, pop those out and you can get your hand behind the radio to push it out.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    if you have the right keys push them in then pull to the side while pullin towards you
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Why dont you just buy one of these disc cleaners and put it in NCDC ? If that doesn't cure it then laser has packed in and im afraid these are common problems with this unit
    Irmscher Insignia CDTI 130
    Aug 2011
    West Malling, Kent
    update!!
    thanks for the tip of the removal tools from halfords, they were a fiver now but worked a treat.
    i took the unit out opened it up....using acetone and a cotten bud wiped the lazer clean...it dodnt look dirty but the bud had become light grey!
    put it all back together, put back in the car and presto worked a treat..the sat nav disc used was a 2009 - 2010. i put this in without any firmware and the car did an update from this disc, it works fine and very well...if anyone requires anymore detail please let me know
    Russ
    By farley2708 in forum Northern Ireland (RO - Vacant)
    Last Post: 10th November 2013, 10:30
  2. Run to the sun 2013
    By shb1988 in forum South East (RO - Scotty80, ARO jaqubek)
    Last Post: 22nd February 2013, 20:20
  3. pvs 2013
    By bezzboy in forum General Chat
    Last Post: 21st January 2013, 22:49
  4. cdc 2013
    By Marty J CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2007, 23:54
  5. Colour screen for NDCD 2013
    By robscott40 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2006, 14:05
