Thread: Understanding the EGR Valve
    Jun 2011
    Nottingham
    Default Understanding the EGR Valve
    I’m after a bit of advice with regards the egr valve; I have a 120 cdti which is just recently started jerking under 2000 revs mainly from cold. After reading around regarding the egr valve and not being very mechanically minded I have a few questions
    1 what dose the valve do
    2 I see a lot of people have blanked it off, what are the long term benefits in this
    3 are there any long term side affects, (surly it was fitted for some reason)
    4 What do you use to blank it off and is it simple to do
    Sorry for the question but it will help me understand and clarify a few thing’s and hopefully help me decided weather to buy a new one or just remove it.
    Regular Member bigdave1701's Avatar
    York
    I have a very limited understanding of the EGR but as I see it:
    1. It recirculates exhaust gasses into the engine. The idea behind it is to give a more complete burn of fuel, lower combustion temps and reduce the production of harmful exhaust gasses
    2. Blanking prevents exhaust fumes being recirculated and so stops soot building up on the inlet manifold and turning into oily gunk. Improved running at the bottom end f the rev range.
    3. Nope
    4. A blanking plate from eBay costs about £4 and is very easy to do. Undo 2 bolts, slip the blanking plate in redo the bolts. I'll do a how2 if you like?
    Jun 2011
    Nottingham
    Quote Originally Posted by bigdave1701 View Post
    Once I've blanked it off will that be the end of it or do I need to have it remaped?
    York
    Quote Originally Posted by Dale1 View Post
    You'll get the spanner light and eml light when you turn the ignition on. The eml will stay on until you have the EGR mapped out.
    north east
    3. Nope
    I cant seem to find them on ebay can you PM me a link for the 150 ones
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Make one out of a coke can.
    York
    New Member matty87's Avatar
    Jul 2011
    york
    Probably sounds silly but where is the egr valve located. Ive no idea what they look like
    York
    It's on the back right corner between the engine and the bulkhead on the 1.9cdti 150 (dont know about the 120 but I'd assume the same.)
  1. Help understanding Emission Results....
    By Danlisa in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 13:06
  2. Having trouble understanding regional accents ?
    By FIL 4822 in forum General Chat
    Last Post: 9th June 2011, 18:22
  3. Help understanding and buying a home cinema
    By danlat1415 in forum General Chat
    Last Post: 9th May 2009, 19:35
  4. How understanding is your partner?
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2007, 08:33
