Results 1 to 3 of 3
Thread: Bulb warning problem
    Regular Member Majorlook's Avatar
    Leicester
    Default Bulb warning problem
    Hi got an annoying problem with the right rear brake bulb. I get a warning on dash and centre console saying check rear right brake bulb but there’s nothing wrong with it i got so sick of seeing the warning i even changed the bulb but still getting warning. Is there any way of turning it off?
    May 2011
    bispham, blackpool
    theirs 2 bulbs on each side they might be nothing wrong with the bulb when you look at it but their will be something i was constantly getting on my rear left i changed one of the bulbs and it was fine for a few week then it started again checked the bulbs all working then i had enough and changed both brake bulbs on the left cluster and not had a error since
    Double check the bulbs.
    There are 2 tail light bulbs on each side of the car. The upper one is also the brake light. Should the upper bulb fail, the lower bulb takes over the role of tail / brake light.
    Rear light positions (from the top down)
    Indicators
    Tail & brake lights
    Tail lights (which then becomes a brake light as well should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs.
  1. bulb warning
    By dodus in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd May 2012, 17:08
  2. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  3. Warning Bulb gone ?
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 01:04
  4. bulb warning lmp
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 13:30
  5. Bulb Warning
    By rider in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 19:51
