Results 1 to 10 of 28
Thread: Mij exhausts part 2
    Jul 2008
    VXR where are you now
    16 Post(s)
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Default Mij exhausts part 2
    well its been done. the system looks awesome and it sounds lovely on idle but sounded to loud on the motorway, maybe cos i had the back seats down with the old exhaust in the boot?, but im hoping it will quieten down a bit with use, the car threw a hissy fit on the motorway on the way back, id driven nearly all the way back no problems so when a lorry moved over on me i gave the car some welly then all of a sudden the speedo stopped working, the abs light came on then followed by the steering wheel light?? wtf!!! i switched the ignition off and on and it reset but then the speedo stopped again followed by the steering wheel symbol grrrrr now im thinking the worst so i pulled over and got my handheld code reader out and read the code and it told me it was a speed sensor. i cleared the fault and it didnt do it again the rest of the journey???? and ive just plugged opcom into it and it read loads of faults in the abs ,steering sim, tc, cruise control,speed sensor and a airbag???? but no faults active so cleared them and they've not come back yet
    i hope MIJ havnt spiked my ecu's????
    anyway here are the pics
    before
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    nice though i expect like me they will tell you to remove the vxr badge lol
    got a video of the sound yet?
    Jul 2008
    16 Post(s)
    before
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Nice. The sound will actually deepen and get a bit more throaty with time, if you find it too droney for you, you can always get a middle box added another time (although I wouldn't with mine as I like the throaty rumble lol. They're good guys up there, was it Dan that did yours?
    The other symptoms you describe sound horribly like an alternator on it's way out to me, I'd test it. Stick a multimeter across the battery with the engine running and everything possible electrical switched on (heated screen, blowers, lights etc etc etc) you should still see it charging at somewhere around 12.8 to 13 volts even under that load. With everything off and the engine running you should see about 13.8 or so.
    Jul 2008
    16 Post(s)
    god ian i hope it dont get louder probably just sounded worse cos the back seats were down i hope lol
    when it had its glitch the alternator was the 1st thing that went thru me mind so went into the settings menu and checked the voltage it was 14.2 normal and 13.8 under load so im a bit worried that they spiked a ecu cos the alternator seems fine
    and its not done it since???
    Jul 2008
    16 Post(s)
    right just checked the car with oocom again no fault codes, battery voltage 14.2 and the lowest with everything switched on was 13.6 so i hope the alternator is fine just seemed strange that it only did it when i gave the full beans i have a feelin that they spiked a ecu or my speed sensor is spiked
    Regular Member hagga's Avatar
    kingswinford
    most of those faults point to the cim... mine came up with those errors bar the speedo...
    Regular Member R2XPT's Avatar
    Scotland
    Those pipes are stunning, fit and look perfect, makes me wanna change my system now
    Jul 2008
    16 Post(s)
    in all the fault code readings it mentions the speed sensor and the 1st reading on my hand held said speed sensor as well
    Jul 2008
    16 Post(s)
    Quote Originally Posted by R2XPT View Post
    they do look the dogs danglys fella
  1. Replies: 70
    Last Post: 15th October 2008, 18:51
  2. My busy week part 3 (3rd & final part ;)
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2007, 17:13
  3. Exhausts
    By Steve-E in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 20:40
  4. new exhausts
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2006, 17:30
