Results 1 to 3 of 3
Thread: The problems just keep rolling on?
    uk
    Default The problems just keep rolling on?
    The problems just keep rolling on:
    Recap
    Hunting and erratic revs (although smooth), whilst in the middle of sorting this: water pump seized, shattered and took out 16valves. So basically rebuilt/refurbed from the block up.
    Picked it up and identified that it was not smooth and idle revs steady at 1100. Advised to run it for a few days to allow for learning.
    Soaked the EGR and it started working – revs dropped to 600 BUT! this showed the miss firing up – code say no.2.
    Garage said we need to cut out the possibility of the coil pack, bought one and put it on – still the same (another £65 wasted). Started moaning so today the garage arranged for a portable tech to test.
    Nice bit of kit, blue tooth to their van! It showed up 2 faults, EGR (permanent) and no.2 miss fire (intermittent).
    When I had the car back I was having problems starting it – now we know the problem for sure. I asked if he could bypass the EGR now or after it was blanked off. He said it will not make any difference and turned it off saying it will run ruff until you blank it.
    The thing would not now start and when it did it would not hold idle revs! Held the revs at about 2000 and it was still missing. Diagnosis – mechanical, maybe air leak by no.2 cylinder, air inlet manifold or worse?
    Left the car with them (no choice revs dropped like a ton of bricks). They are going to blank the EGR and investigate. At least they have lent me a car, I will only use it in emergencies because it is a bit of a knacker.
    1.8, 02, club
    All I can say is
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    jeezz mate sound mad hope ya sort it keep us updated
    uk
    An update and a question
    I have got the feeling that my car is not top priority in the garage and that they are unsure of what the problem is! I do not understand why they are concentrating on the EGR if it as been switched off at the ECU, surely a blanking plate would discount that completely? Apparently they had blanked off the EGR on a temporary basis and the engine seemed fine but when they done it with a plate all was back to as it was.
    I need your assistance here (and to help the garage: wink, wink) Leaving the EGR out of the equation, with it not holding revs and the only error code being intermittent misfiring on cylinder 2. What could be the causes?
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. Rolling Around
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2006, 19:32
