Results 1 to 10 of 18
Thread: Green Plug
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    Default Green Plug
    Hey,
    I was retro fitting Insignia washers to my car last night and when I lifted the Scuttle panel to remove them I noticed a cable with a green plug/ connector on it. It was not connected/plugged into anything and I was just wondering if anyone know what it is for.
    My car is an 02 2.0DTi LS Hatch, if that makes any difference.
    Cheers in advance
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Next to the pollen filter? It's for heated washer jets
    Mar 2011
    Warrenpoint, NI
    Yeha thats the one, I know i have just changed to insignia washers, but is it hard to retrofit the Heated washers? or can i fit heated Insignia washers??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The insignia uses a heated washer bottle iirc so it's jets can't be heated. You can however fit normal heated jets with the heating loom. It's 100% plug and play
    Mar 2011
    Warrenpoint, NI
    Sweet, handy for winter! Being really cheeky now, do you know part numbers???
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Mar 2011
    Warrenpoint, NI
    John, you are a legend!!!!!! Now wonderign what other secrets my car holds....
    Mar 2011
    Warrenpoint, NI
    Will this work?
    http://www.ebay.co.uk/itm/VAUXHALL-O...item518ff280fb
    BTW John, just realised the green plug under the scuttle is on the other side of the pollen filter, in my car. Will check if I have the plug show in your pictures on the "HOW 2"
    Mar 2011
    Warrenpoint, NI
    Bump!!!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    They are normally cheaper from the dealer mate.
    Have you checked the plugs yet
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. preface gid screen plug, is it the same as the 32 pin vec b mid plug?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 23:15
  3. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  4. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
  5. green, green eyes...
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2006, 18:01
