Results 1 to 10 of 11
Thread: Glow Plugs or Temp Sensor?
    Jul 2011
    kent
    Default Glow Plugs or Temp Sensor?
    My car wouldn't start this morning. Eventually got it started after turning over for ages. Obviously the plugs aren't working but I already knew that because the coil light has never come on before.
    It hasn't been an issue as the weather has been warm and has always started first time.
    Could this be something other than the plugs like the temp sensor? As surely the coil light would come on even if the plugs were faulty?
    Jul 2011
    kent
    Anyone?! It's an 03 2.2dti btw.
    West
    Try unplugging the temp sender plug, it would normall force the glow plugs on & bring up the light... the dti's don't normally use the glow plugs until the ambient temp is around 5*c or less
    Jul 2011
    kent
    Where is the plug mate?
    West
    iirc... looking at the enging from the front bumper, it's on the left at the front, there's 2 close together... the top one of the 2 is the one to activate the glow plugs.
    hth
    Jul 2011
    kent
    Hmm.. Any pics anyone? :-)
    West
    Although the pic in the link is a Vectra B, it's in the same location as the C
    http://media.photobucket.com/image/v...ymate/cts1.jpg
    Jul 2011
    kent
    Ok thanks mate.
    Jul 2011
    kent
    Yer unplugged the sensor and they came on. Anybody know the part number for one?
    Sep 2011
    Sipson
    hmm, I'll have to try this too, I don't recall having seen the coil light at all, even when on ignition 1 when all lights are on, there is a crack bottom left of my instrument cluster, so filthy thoughts like a cluster swap for a petrol one, which would maybe explain why my revs on a 2.2dti are registering 500rpm less than what they should be, assuming the petrol and diesel clusters are different.
    EDIT: ahh derr, of course they are different, RPMs lower on a diesel, so I do have a diesel one, need to check for the glo light then cos my car can take 7 or 8 cranks to start too.
  1. Glow Plugs
    By billwwhyte1 in forum Engine & Drivetrain
    Last Post: 7th February 2014, 23:27
  2. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  3. Glow Plugs
    By st2malo in forum Engine & Drivetrain
    Last Post: 10th February 2010, 19:26
  4. Is there a how 2 for glow plugs
    By jacko52 in forum Diesel Engine related
    Last Post: 15th January 2010, 18:04
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
vectra c glow plug temp sensor
vectra c 2.2 dti glow plug temperatures
