Thread: Side lights off with dipped beam ?
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    Default Side lights off with dipped beam ?
    I wonder: is it possible to tech2 (or vaux-com) so that the side lights go out when you turn on the dipped beam ?
    Here in Sweden most cars are wired/programmed to have the dipped beam go on with the ignition, along with the side lights. Only way to turn off the headlights is by using the middle "side lights only" setting on the light knob. So, all in all it is impossible to drive around with all lights off on my car, an i do¨'t mind that, its just that i want the side light to be off in the "full on" position and then i could wire up my DRLs on the side light wire.
    anyone tried things like that on the tech2?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes Tech2 can turn of DRL.
    Front is controlled in the UEC and the rear in the REC.
    You cant have the sidelights off when you have turned the "knob" on..
    May 2008
    Sweden
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    Quote Originally Posted by kenp View Post
    OK, i'll solve it with a couple of relays then
    Engine : 2.2 Direct
    Yours is a facelift if i remember correct..
    Retrofit rain/lightsensor..
    and have it working that way.. automatic..
    May 2008
    Sweden
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    if i would retrofit anything it would be fog lights
    btw, i dont think aut headlights would do it...
    what i have is :
    pos 1 (off) dipped and sidelights on, no dimming of dash, no full beam
    pos 2 (sidelights on) sidelights on (duh) , dash dimmed
    pos 3 ("ON") dip and sidelights on, dash dimmed, (very) full beam if i want.
    the only change i need is pos 3: to dipped beam only, and full as required....
    oh, here´s a "sweden lights" pic for you Ken !
    Engine : 2.2 Direct
    Sorry what you wnat isnt possible with tech2.. you have to do it with relays..
    always like those "swedish" lights .. you can never miss them.. even 1 (UK) mile away.
    May 2008
    Sweden
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    yysnet posted a howto on dimming mirror and auto headlights, he also modified the light switch. Seeing that gave me some ideas. http://www.vectra-c.com/forum/showthread.php?t=120163
    Need to work out how its hooked up
  1. One dipped beam dimmer than the other...
    By y2joeyb in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 15:45
  2. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  3. Dipped Lights/ Lower Beam
    By jatint in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 18:58
  4. Dipped beam adjustment
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 07:06
  5. Dipped beam
    Last Post: 23rd October 2009, 01:35
