Results 1 to 10 of 14
Thread: Offside track rod end ball joint has slight play
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default Offside track rod end ball joint has slight play
    Got this as an advisory in my MOT.
    Has anyone replaced these themselves and if so whaat are they like to do?
    also got:
    Nearside rear upper torque/reaction arm has slight play in a pin/bush.
    Slight play in steering nearside.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Track rod ends are a doddle to fit, but need tracking afterwards.
    Literally wheel off, undo the nut, tap free, loosen the lock-nut, unscrew track rod from the steering rack - refitting is reversal of removal (to coin a phrase). They aren't that expensive, so always recommend doing both sides while you're at it.
    Apr 2008
    North East
    nice one, cheers Dan
    from what the advisory says, do you also think it means the inner tie rod aswell, or is that not necessary?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by monkeez View Post
    Can't be 100% mate, but I always recommend doing both sides when doing track rod ends.
    Apr 2008
    North East
    can you recommend some where online where i can order them from mate?
    LMF dont seem to have them
    cheers
    Lancashire
    Trim : XP1
    Mileage : 66000
    Eurocarparts have them, eBay, or a local motor factors.
    Apr 2008
    North East
    Just rang local motor factors and getting the pair of Quinton Hazell ones for £25.
    thanks for the help Dan
    cheers
    swansea
    Mark or count the turns when removing old one, this will help in fitting the new one. Tracking still needs to be done.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    cheers
    TBH genuine VX ones are about the same price
    Apr 2008
    North East
    just rang Vx and they said £25 a side
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. mot advisory offside inner steering rack joint has slight play
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 12:29
  3. Replies: 6
    Last Post: 13th March 2011, 10:47
  4. Ball joint separator for track rod ends
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 26th May 2010, 16:00
  5. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
track rod end ball joint slight play
vectra c inner tie rod removal
slight play in ball joint
slight play in inner rod on a.corsa
vectra c track rod end
spinning track rod end vectra c
