Thread: auto window only on pass side ?
    Question auto window only on pass side ?
    hi guys piked up the vec yesterday and whilst playn around found out that only my passenger side front window will auto go up/down ..Drivers side i have to keep my finger on till fully up or down, any ideas guys..
    m.t...micky
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Er the one touch needs to be rest there is a how 2 somewhere mate
    Full Member Big Sig's Avatar
    hold the button and wait till it stops and then keep it pressed for about 5 secs, do the same with closing it. This should teach it its new limits.
    cheers paul, if its the same as the pre-facelift,
    ignition on
    lower the window
    close the window
    hold up button for 5 secs till bleeps
    job done...
    however job not done, had a scout around on here but to no avail...
    never mind...
    micky.
    WGAF#5
    Micky,
    i would imagine the drivers side contacts in the switch have got dirty.... really easy to take apart (watch out for the springs !!) and then clean the PCB with a pencil rubber ... then reassemble and retest
    hth
    regards
    Dez
    cheers mate, will give that a go...
    it does go up /down if i hold the switch, just not 1 touch up/down....ALSO, if windows are open when i lock car and keep finger on lock button, windows (both sides) go up, however, when unlockin neither go down ?
    cheers micky..
  1. Side Window
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2007, 22:17
