Thread: Overheating Z20NET? Help!
    Aug 2009
    Leeds
    confused Overheating Z20NET? Help!
    Wonder if anyone can help me shed any light on what's up with my Vectra 2.0T SRI?
    About two weeks ago my engine began to over heat, heard what i thought was the water pump so stopped.
    The car then went into Evans Halshaw, Horsforth for a new water pump fitting. (This in itself is a story to be told, but after 5 days later i got my car back with a new water pump)
    Upon collecting the car from the main dealer, they told me that they had not started the car since fitting the new pump as they were unsure what damage had been done previously by the old pump, but they had put new coolant in.
    Anyways on my way home the car again over heated after about 10 mins of driving.
    Eventually after getting it home, i've changed the thermostat, tried bleeding the system to check for airlocks.
    The car still over heats, i get no heat from the heater and my radiator never seems to heat up??
    I'm out of ideas so anything that can be suggested will be tried!
    Thank you!
    Aug 2009
    Leeds
    Default Sorry forgot to add....
    when i turn the engine off after it's reached about 95 degrees and the fans are kicking in; if i release the cap from the coolant bottle then the coolant backs up into the bottle and the radiator top then becomes very hot as if hot coolant is now flowing into it.
    Again any help would be greatly appreciated!
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    when you have the engine running can you see coolant returning to the header tank?
    Aug 2009
    Leeds
    Yeah, if the engines been running and is warm i can see coolant coming out of the pipe that returns to the coolant bottle, (the small pipe at the top of the coolant bottle, that comes from the top of the engine).
    The other small pipe which connects the radiator to the coolant bottle is always cold and i can;t see any fluid flowing from this one.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    it seems you have some coolant flow then.. I would be tempted to take rad off and and tip out the crap and put a hose to it to try and flush it as my first thing.. I guess they did not show your old water pump so you could ascertain if the impeller broke apart..
    I am not near my car right now to check the path of the coolant to see the pipe you refer to as being cold..
    Aug 2009
    Leeds
    Cheers, that'll be my next step then. No I saw my old one and the impeller was ok, but not smooth at turning over.
    My probs had started when the timing chain guide had broken.
    It's all back together ok, but just won't stop overheating!
    Thanks though, any further advice would be much appreciated.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sorry I cant help re the coolant but steer well clear of that dealer, I had to get a new engine fitted because of them, and VX had to stump up £8500 to get it running again....
  1. Overheating
    By Steve1974 in forum Engine & Drivetrain
    Last Post: 6th May 2013, 13:52
  2. Z20NET Overheating / Head Gasket?
    By ropa83 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 20:38
  3. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
why i my vectra c diesel engine getting hot
z20net ol pumpe problem
vectra z22se water pump impeller broken
z20net cooling system bleeding site:www.vectra-c.com
z20net overheating
