Thread: 2.0 turbo whistling over 3500 revs
    Worksop
    Default 2.0 turbo whistling over 3500 revs
    Dez says it might be cause of remap and airbox mods any more thoughts?
    WGAF#5
    well lets give them a bit more info shall we otherwise its very ambiguous
    a remapped 2.0T with holes drilled into the air box ...smaller turbo spooling at higher revs
    sounds similar to an open filter system when fitted around/above 4.K revs
    as per my thread and videos within
    http://www.vectra-c.com/forum/showth...t=bsr+optiflow #
    and there is no loss of power or eml on to suggest an air leak
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    show some pics of the airbox and what you did to it.. I did mine and had no problems..
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Mine whistles a bit too and it's become more noticeable since I drilled it. Only does it at high revs though, so I've always just put it down to more air being sucked in fast through the drillholes.
    Worksop
    Drilled it same as ians air box quite a few large holes on front and side
    Worksop
    Quote Originally Posted by Ian-Highlander View Post
    Is it like a high pitched whistle Ian above 3500-4000 revs
  1. Turbo making a louder whistling noise
    By stupot555 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 22:30
  2. 1.9cdti Turbo - Very Loud Whistling/Spinning Up
    By countduckula55 in forum Engine & Drivetrain
    Last Post: 19th January 2012, 00:02
  3. whistling noise after fitting turbo back sstem
    By tomo41 in forum Engine & Drivetrain
    Last Post: 17th August 2011, 22:52
  4. whistling while on boost 2.0t seems to start about 3500
    Last Post: 13th August 2011, 22:22
  5. whistling turbo
    By jonah8742 in forum Diesel Engine related
    Last Post: 24th February 2011, 15:33
