Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: How do I work my Auto rain-sensing wipers?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default How do I work my Auto rain-sensing wipers?
    Hello, im trying to get my rain sensing wipers to work.
    I was under the impression that when I start the car, I simply push up once and leave it be.
    So when I do this, the wipers wipe twice then stop, then they just seem to jump into intermittent mode and only wipe with quick intervals or long intervals, as per the control on the stalk. Am I missing something?
    Can someone please assist?
    Thanks.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    If working, then its one press up (as you say) and that's it. The adjuster on the stalk is to alter the sensitivity (where on a car with no rain sensor, this would be to alter the intermittent frequency).
    Is it raining?
    Birmingham
    Spitting, so thought I would give it a try?
    What would stop this working?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Vaux-Man-G View Post
    Maybe the sensitivity is too low as its spitting
    You 100% got the rain sensing wipers..?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    best to test in the dry.. push up once and the wipers shouldn't move at all. Leave it for a bit then move the roller up a level, it should wipe once then stop again etc..
    Birmingham
    As far as I know. How can I check for sure??
    Regular Member AndyMaz's Avatar
    Aug 2011
    Kent
    The way I thought it worked from playing about with mine, is that you press the stick upwards once, the wipers then wipe twice and stop. After that it'll sense the rain hitting the sensor behind the rear view mirror on the windscreen and adjust the speed automatically depending on the amount of rain hitting the windscreen at that moment in time.
    So if it's spitting, there may not be enough rain to trigger the sensor, so the sensitivity needs adjusting up.
    Aug 2011
    Kent
    There should be a sensor on the windscreen by the rear view mirror, you can only see it from outside.
    Aug 2011
    Kent
    Birmingham
    The sensor is present. This morning with sensitivity on low, it still continued to wipe at long intervals. Then with zero rain at one point on totally dry screen on m'way it still wiped at selected intervsls rather than on auto when it shouldnt be wiping at all.
  1. Auto wipers/rain sensor not working
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:11
  2. Auto wipers.. How do they work?
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 21:57
  3. Rain sensing Wipers
    By Signum Dek in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2010, 01:08
  4. Rain sensing wipers
    By thechief in forum Vectra C / Signum Troubleshooting
    Last Post: 8th April 2010, 14:40
  5. Rain Sensing Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 08:51
how do i know if my meriva b has rain sensing wipers
