Thread: New clutch and DMF but still vibration in pedal
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Default New clutch and DMF but still vibration in pedal
    Hi All,
    As the title says, I just had a new clutch kit and DMF replaced, and all the rattling disappeard, thank god, but I have now an annoying vibration on the clutch pedal only felt when pressed about an inch or so beyond the slack, otherwise everything else feels great.
    I have looked at all the posts concerning this problem (if it's a problem) but opinions seem divided. Any help would be appreciated.
    EVERYWHERE
    This can occur if some of the components are slightly warped or out of balance. What you can usually feel is the clutch release bearing moving slightly up and down the input shaft of the gearbox as the clutch spins around. You could change the clutch a hundred times and you might still get the same problem for each one. Not really a problem as long as the clutch works OK (no grabbing or slipping). Can go away by itself in time.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Did they replace the clutch release bearing? Check the invoice for the work which was carried out and the parts that were replaced. They should of replaced the clutch bearing, clutch and DMF. If it's not the bearing then the DMF is possibly at fault, get back to the garage who carried out the work. That's the best bet, as getting them to sort the DMF has not remedied all symptoms.
    Jul 2011
    Daventry
    I have exactly the same issue, very noticeable pulsating when pressed about 2 inches, this is AFTER new DMF, Clutch and CSC were fitted 2 weeks ago, it can on occasions be very pronounced at Idle and a bit of a concern tbh, have been told by fitter that this is normal, was never there before until a week before DMF started playing up and even then it was only slight
    Any thoughts
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    i had this on my VW passat and i just lived with it.It was like when when i brought the car and 2 year later it was still doing it BUt was working fine.
    My Veccy also does it but im not worried at all about it
    Jul 2011
    Daventry
    Ok if the above is correct where was the vibration for the 1st 60k and i have had 2 of these??
    Sodding Typical on Sea
    I have it on mine now after the new DMF was fitted I got E/H to inspect it when it was in for service so that there is a record of my reporting it if,,,, it does go during the next year of my warranty
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    I've had 4 diesels, all of them DMF, and the vibration has been present in all of them. I wouldn't worry.
  1. clutch pedal vibration,noisey
    By freelanderbri in forum Engine & Drivetrain
    Last Post: 19th November 2012, 14:30
  2. Clutch pedal vibration
    By Ianz in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:41
  3. Clutch Pedal Vibration - 150 CDTi
    By Hopewell in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 14:28
normal slight vibration in clutch astra
https:www.vectra-c.comforumshowthread.php145390-New-clutch-and-DMF-but-still-vibration-in-pedal
slight vibration on clutch pedal opel corsa
vectra c vibration through clutch pedal
why car astra cdti j juddering
clutch pedal still vibrates after new fit
vibration on my clutch in a corsa
vauxhall astra h vibration in clutch pedal
astra 1.9 cdti heavy clutch vibration
new clutch vibration
astra j clutch pedal judder
clutch pedal vibration vectra cdti
vauxhall zafira clutch pedal vibration
vibration through clutch pedal vectra c
vectra clutch shaking
vauxhall insignia bad vibration dmf
astra j clutch vibration
vectra c clutch pedal judder
vectra clutch pedal heavy and vibrates
vectra c cdti faulty release bearing
vectra c clutch pedal vibration
new clutch slight vibration on the pedal
astra h clutch pedal vibration
astracdtivibrationonclutchpedal
vibration 5hrough clutch peddle vauxhall insignia
