Results 1 to 10 of 13
Thread: Fault: a car with a lock
    New Member saragde's Avatar
    Aug 2011
    Vilnius, Lithuania
    Default Fault: a car with a lock
    My signum won't start and shows this car with lock
    what it mean? how to switch off it? a car key doesn't work too
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Imobilerser mate somet up with the key of transponder
    Aug 2011
    Vilnius, Lithuania
    immo has been programed successfully, but still the same fault and the car won't start
    Chelmsford
    Who did the programming?
    Definitely an immobiliser problem.
    I had this years ago on my Vec B, the keys had been dropped and the plastic casing came apart. I clipped it back together and thought nothing of it, until the car wouldn't start. Turned out the immobiliser chip had fallen out. Found it and put it back and all was fine.
    Have your keys been dropped or knocked hard recently?
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by saragde View Post
    Needs looking at again or re-programming. The immobiliser system doesn't recognise your key as valid, the code in the transponder does not match any known by the Immobiliser.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by DNS View Post
    Thats was exactly the same as my mate and his Zarfia. Garage man who came and saw him at work happen to notice the chip on the ground right next to the car. Once put back in he could start his motor again.
    Aug 2011
    Vilnius, Lithuania
    how does that chip look like? I've open my key and there is only a microsheme
    Aug 2011
    Vilnius, Lithuania
    btw a mechanic has programmed new key which was sucessfully programmed but the lock didn't dissapear
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    He hasnt done it successfully then
    The symbol shows that the code in the key doesnt match the car
    uk
    Definitely the immobiliser, the two are not paired. (key and sim)
    Don’t know if this will work but it did for a steeler. They changed the battery in one of my keys and when I tried to open the doors or start the car the lock came up. He locked the car with the other key put the key with the new battery in the drivers lock (without turning) and held down the open button for 30sec. pulled it out and it worked fine?
    Worth a try!
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Is it going to lock me out
    Last Post: 3rd August 2012, 07:44
  3. Never mind lock up ya daughters, lock up ya vectras!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 21:45
  4. Replies: 15
    Last Post: 9th July 2011, 22:19
  5. Air lock?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 02:26
