Results 1 to 10 of 11
Thread: Which machine polisher?
    Chelmsford
    Default Which machine polisher?
    Wanting to properly de-swirl my nice "hologram effect" black sapphire bodywork.
    Got some Megs Ultimate Compound a while back which I applied by hand and with my cheapy machine polisher.
    Want to do it again with a machine with a bit more balls.
    The Megs DAs are a bit overpriced in my opinion, can anyone recommend an alternative?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I went with the Kestrel DAS-6 Pro from another members recommendation. Over the standard DAS- 6 it has a bigger, beefier motor and a much longer lead. I've had no problems with it. If you check around, Autobrite, Detailing World or Cleanyourcar.co.uk, someone's usually got an offer on.
    I also went with the Chemical Guys hexologic pads, on same person's advice, as being more up to date and better than the ones he used.
    Chelmsford
    Thanks mate, I'll check them out.
    Chelmsford
    Forgot to ask, is it definitely best to go for a random orbital polisher? Am I really likely to do a lot of damage to the paintwork if I screw up with a normal rotary?
    Start off with a DA. Grumpy1954 - excellent advice.
    hi mate i used one of these http://www.ebay.co.uk/itm/Porter-Cab...#ht_500wt_1156
    [IMG][/IMG]
    sapph black and look at the shine...
    Chelmsford
    Cheers for the advice guys, I'll see what I can pick up.
    Been desperately wanting to properly de-swirl my car for years, just never got off my backside to do it.
    Woodbridge
    I think grumps has hit the nail on the head. The only thing I would change from that set up is megs UC, it does work well, but there are products out there that can do the job in half the time.
    Jun 2011
    Kent
    I do bodywork and I can recommend a silverline rotary polisher with soft start and there is no need to go over 2000 rpm, minme does 3k rpm but I only ever use it on setting 2 (of 10)!
    Get some decent polishing heads and some Farecla G6 compound - this can be used dry but I recommend using it with water.
    Finish off with Farecla wax which lasts months and beads water off like a ducks back!
    The polishers can be bought from ebay for £65, the G6 polish is £20 and the wax is £15.
    I did a Civic Type R and an A3 at the weekend and they both looked amazing, particularly the A3 as it was metallic black and had a fair amount of swirls before polishing but looked like it had just left the factory after the polish and wax.
    Jul 2011
    Heanor, Derbyshire
    Quote Originally Posted by DNS View Post
    If you have time to practice on a scrap panel then a rotary is fine, i started off with a rotary and have had great success with it, just use common sense, dont go too mad, keep the pad moving and be careful around edges.
  1. Machine polisher
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 13th March 2012, 07:24
  2. Machine polisher
    By david.91.09 in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 21:58
  3. Machine polisher
    By aerodynamic18 in forum Northern Ireland (RO - Vacant)
    Last Post: 12th May 2009, 22:57
  4. Machine Polisher
    By lizard in forum Detailing and Car Care Discussion
    Last Post: 1st November 2008, 23:00
  5. machine polisher
    By kgsric in forum Detailing and Car Care Discussion
    Last Post: 24th June 2007, 10:56
