Thread: MOT ALL brake pipes badly corroded
    Regular Member formby's Avatar
    paisley
    Default MOT ALL brake pipes badly corroded
    Just had car in for MOT failed!!!
    offside track rod end ( fair enough)
    nearside front brake pipe excessively corroded
    centre to NSR brake pipe excessively corroded
    centre to OSR brake pipe excessively corroded
    offside rear brake pipe excessively corroded
    nearside rear brake pipe excessively corroded
    front exhaust bracket snapped
    offside front brake pipe slightly corroded
    front (above axle brake pipe slightly corroded
    WTF
    is this normal
    Jan 2008
    ireland
    buddy had similar issue with toyota corrolla recently, all the salt over the winter mate.... bad times.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    I had to have a few brake pipes changed for 2010 Mot but it was ok this time
    Regular Member Garfo's Avatar
    plymouth,devon
    mine failed on front ones last mot was like wtf on a 2006
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    mines is a 05 plate got i adnotice from the mot center about the from the center of the car to the back ones..
    Mine booked in next week for copper ones....
    When ya get them done get them done in copper
    Sep 2010
    north east uk
    Copper all the way. Had all my old vectra B pipes changed using copper piping in 2006 & they were still good as new when i changed it for my C last year.
    Jul 2009
    The Rift, Cardiff
    i had the same on my old golf. WD40, a soft wire brush and some wire wool had it sorted, passed on the retest no problem.
    Regular Member sheepish's Avatar
    Yorkshire
    Adding to the copper thing, I believe cupro nickel (90% copper, 10%nickel) lasts even longer/is even more corrosion resistant...
    Jul 2011
    Heanor, Derbyshire
    Depends if they are corroded or just surface rust. a garage i used to used seemed to have a thing about brake pipes and failed a number of my cars on them. when i looked it was very minor surface rust, so a quick rub down and repaint job done
    Of course if they are badly corroded then replacing is the only sensible answer.
  1. Brake Pipes
    By st2malo in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:46
  2. brake pipes
    By DTi Elite in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 22:00
  3. Brake pipes corroded.anyone help?
    By Dobs in forum Suspension, Wheels & Brakes
    Last Post: 30th November 2011, 23:03
  4. corroded front and rear brake discs.
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 22:45
  5. Corroded front brake pipes
    By sheepish in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2010, 14:04
badly corroded brake pipe
vectra c offside rear brake pipe
corroded brake pipes
vectra c brake pipe diagram
vauxhall signum brake pipes
brake pipe vectra c
brake pipes vectra
https:www.vectra-c.comforumshowthread.php145337-MOT-ALL-brake-pipes-badly-corroded
all brake pipes corroded
vectra c corroded brake pipes
brake pipes corroded on vectra 2006
vectra brake lines.corroded
