Thread: Changing over insert on gear knob
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Changing over insert on gear knob
    guys does anyone know if the plastic part that covers the gear pattern on the top of the gear stick can be changed? I have cracked mine and now have bought another gear knob and would like to just change the plastic section rather than the whole gear knob. Does anyone know if this can be done? Thanks
    Bucharest
    Hi,
    At least from my experience, the plastic part of the normal Vectra C knob, slides off upwards from the knob itself just like a cap. I had a leather one and when the leather wore off I was looking for ways to get it off. You need to use a blade or something to dislocate it from the base. Do it carefully though because these things are fairly tough and you want to avoid damage to it. I hope this helps.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    depends on your knob fella post a pic up lol
    Aug 2007
    Lisburn, N.Ireland
    im not showing u my knob lol pmsl. I have the sri one and i found that the plastic insert is held in by 3 spiggots so i removed it from the new one and put it in mine so now all sorted . The reason i did this was the leather on mine was in better condition than the new one but all i needed was the insert lol.
    Full Member lizard's Avatar
    Oct 2006
    southampton
    14 Post(s)
    i used a 12" stainless ruler, start by inserting it at the base and instead of forcing upwards, twist the ruler left and right to gently get it started and the rest is simplez...
  1. XP2 Gear Knob Insert
    By lofty in forum Parts for sale
    Last Post: 13th December 2010, 23:33
  2. XP2 Gear Knob Insert
    By leeds vectra in forum Parts for sale
    Last Post: 8th May 2010, 12:46
  3. gear knob insert
    By simon1 in forum Parts for sale
    Last Post: 21st July 2008, 17:58
opel vectra c gear knob cap
remove vectra c gear knob insert
the plastic top of the gear stick for a vauxhall vectra
corsa c gear knob insert
insignia automatic gear stick plastic insert
how to change gear knob on a vauxhall vectra c vxr
how to change the gear knob on opel corsa
vectra gear knob insert
