Results 1 to 10 of 20
Thread: richbrook door pins
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    Default richbrook door pins
    as anybody got there door pins fitted, so that when the doors are locked the pins dont show? (just like the normal plastic factory ones) its it possible?
    Regular Member OllyT's Avatar
    Jul 2011
    Northampton
    im pretty sure that generally they do show even with after market door pins,
    im not sure how i did it but i took the door card off the other day and when i put it back on the door pin is lower, so its possible but not sure how
    Jan 2008
    leeds / wakefield
    im concidering trimming them down..... also the back ones sit higher then the fronts
    Jul 2011
    Northampton
    if you take the door card off then u may be able to bend the wire there attatched to to make them stick up less?
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I cut the rears with a dremel to make them sit correctly.
    I'll take some pics of them on the car and post them up shortly.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Mine were second hand, may be Irmscher, have twin rubber O rings. The rear ones were trimmed to sit at same height of fronts, but even at best I could do, the bottooooooom O ring and above shows.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hope this helps.
    I did want them to go a tiny bit lower but then that means removing the door cards. A bit too much hassle just to fit door pins.
    Heres what mine look like.
    Front Up
    Front Down
    Rear Up
    Rear Down
    Rears cut down to around 42mm
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Yep, mine about the same as Envy's.
    Jan 2008
    leeds / wakefield
    thanks, all. cheers for the pics! im going to saw them down to same lengh in photo. just been looking at them, it wont be possible to get them fully down when locked.
    peterborough
    cutting the pins down won't make them sit any lower unless your cutting that length off the top of the pin! it's the depth of the hole or the length of the rod that defines the height of the pin! you will need to drill the hole of the doorpin deeper or cut the rod shorter
  1. Chrome Richbrook door pins
    By Ben50n in forum Styling
    Last Post: 27th January 2012, 14:13
  2. For Sale: Richbrook door lock pins
    By chrisvectra in forum Parts for sale
    Last Post: 25th January 2012, 19:48
  3. Richbrook alloy door pins x 4
    By blues n twos in forum Parts for sale
    Last Post: 3rd August 2010, 20:34
  4. richbrook door pins
    By topgun in forum Styling
    Last Post: 21st August 2009, 22:28
  5. richbrook door pins
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2006, 22:30
