Thread: Couple of I.C.E questions
    Regular Member Deann's Avatar
    Mar 2011
    England
    Question Couple of I.C.E questions
    Hey guys,
    I had a couple of questions regarding potential I.C.E in the vectra.
    1) I will be fitting a double din head unit, how snug is the fit or will I need to buy some sort of fascia?
    If so which one do you guys go for?
    2) What size are the speakers in the front and rear?
    3) Are speaker pods required for the front or rear?
    If so which ones do you guys go for?
    4) With regards to installation, has anyone ever run 0AWG through the car? is it easy, and which side did you run it down (drivers/passenger)
    5) Is there already an un-used grommet somewhere in the vec for passing the 0AWG cable from the battery into the car or do you usally have to drill your own?
    That's all I can think of for now
    any pictures of your guys installs would be interesting, I'm just purchasing the last few bits for mine
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    http://www.vectra-c.com/forum/showthread.php?t=15590
    that should help u in running the wire from the battery
    i have a jvc double din unit in mine and it does need a facia surround
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    1. Yes you need a fascia kit. The standard double din cage that comes with radios won't fit, so you make sure you buy one with a cage too.
    2. All Vec C speakers are 6.5"
    3. Yes, the Halfords plastic ones will do, but your front door panels will bulge slightly if you use them (the fit the back fine), alternatively knock some up out of MDF.
    4. Haven't run 0awg but have got 2 x 4awg running down the passenger side (see my thread in the ICE forum for pics).
    5. Most people punch the cables through the main grommet behind the glove box (again pics in my ICE thread).
    Chelmsford
    Last time I did an ICE upgrade was with my Vec B. Headunit makes by far the biggest difference. I put an Alpine unit in and when I heard it I didn't bother replacing the speakers.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Run my 4 AWG cable through an unused grommet but it will take 0 AWG:
    http://www.vectra-c.com/forum/showthread.php?t=129626
    My picture is #9 I think!
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    As above i used the same gromet and i fitted 2 0awg through the gromet.
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    Quote Originally Posted by alzsxi View Post
    Hmm, apparently I changed my picture numbering format after posting my post in that thread as the picture is not what I was describing lol
    Mar 2011
    England
    Just found that I created this thread.
    I'm going to be ordering some components for both the front and back of my car
    So I need 17cm/6.5" speakers for both.
    How easy is it to mount the components for both of these?
    and where is the best place to get the speaker pods from?
    Cheers!
    Mar 2011
    England
    Cheers!
  1. A couple of questions.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 16:16
  2. Couple of questions
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 20:14
  3. couple of questions........
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 14:55
  4. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  5. Couple of questions
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 01:35
