Thread: P0030 Do I simply need a new Lambda Sensor?
    Regular Member jasonmma's Avatar
    Aug 2007
    edinburgh / Livingston
    Default P0030 Do I simply need a new Lambda Sensor?
    Hi guys
    not posted in a while TBH but hoping you guys may be able to point me in the right direction with this code. Car isn't going over 2.5k revs and is giving a tiny blast of black smoke when I first start the engine in the mornings.
    I got a mate who works @ a panel beaters to plug his Snap-on machine in. Here's what we got, his machine displays:
    1.9 Diesel - Z19DT
    p0030 - Heated O2 Sensor Bank 1 Sensor 1 Circuit Open
    The book that came with the machine says this:
    P0030 - HO2S Heater Control Circuit Bank Sensor 1 -
    The heater control for the HO2S (oxygen / lambda) sensoris used to heat up and provide stable temperature for the sensor (primarily after cold starts). The hetaing element can receive a power supply via a relay (often the main system relay) and the heater earth path can be switched to earth via the control unit (this is the heater control circuit), the control is therefore able to control the operation of the heating element by controlling the earth circuit. Note that some systems may also provide the power supply to the heating element via the control unit. It may be necessary to refer to vehicle specific information to identify the type of Oxygen / Lambda sensor and the wiring.
    Do you think a new Lambda Sensor would fix this? If anyone could please offer advice, it really would be appreciated. I'm driving mega slow due to this and am kinda skint so may buy one 2nd hand if thats what it is....
    Any advice would be awesome guys,
    Thanks a million..... Jason.
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Try swapping sensors over if the fault moves you no the sensors faulty
    Aug 2007
    Is it a difficult job to do?
    Chelmsford
    Quote Originally Posted by jasonmma View Post
    If I recall correctly, it should take about 30 seconds.
    Aug 2007
    LOL! Really?
    am off to somehow prop the car up and find it first!
    wirral
    49 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Not difficult at all just run car an get exhaust hot first an will allow them out easier
    Aug 2007
    Done, thanks guys! Made no difference to the way the car drives, still getting lack of power but the EML only comes on intermittently now.
    Cleaned out the EGR valve today too, was chock full of black crap but still no difference....
    Am totally at the end of my tether with this car! Wishing I never had it at the mo TBH...
    Aug 2007
    bump :0(
    wirral
    49 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Does the pedal test bring anything up?
    Aug 2007
    Thanks for asking mate Nah, pedal trick doesn't seem to work on mine. Looks like I'm gonna have a visit to a friend tonight to use OpCom
    Nothing is easy eh?
    I'm getting some white smoke on start-up and not able to go over 2.5k Revs. Major embarrasing driving to work in rush hour traffic LOL
  1. EML P0030 & Lambda advice
    By jasonmma in forum Engine & Drivetrain
    Last Post: 30th August 2011, 12:53
  2. lambda sensor
    By wcr in forum Engine & Drivetrain
    Last Post: 11th November 2010, 00:20
  3. Can you simply run a cdti 150 with the egr sensor unclipped??
    By richiem in forum Engine & Drivetrain
    Last Post: 16th September 2010, 13:59
  4. Lambda sensor - 3.2 V6
    By urbanfox in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 16:49
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
Vauxhall vectra c p0030
vauxhall vectra code p0030
p0030 vectra c
