Thread: ABS light on after lowering springs fitted.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default ABS light on after lowering springs fitted.
    As title suggests. Fitted springs today with help today from my brother in law (I definitely think it's a 2 man job).
    Anyway when i took the car out a run after everything was tightened up the ABS light's on!!!
    Hopefully it's a plug not put on correctly. Will I need to disconnect the battery to clear the ECU?
    I'll update this tomorrow when I've had another look at it.
    The car looks great by the way!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You may have damage one of the front abs wires at the hub when removing the strut. Fingers crossed it is just needing pushed in though
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    found with my abs fault, as soon as the problem was fixed the lights went out
    S.Lanarkshire
    I'm going too strip the front brakes down tomorrow & copper grease them. Hopefully I'll find the problem. As long as I don't need to get the car tech2'd to put the light off as my favourite mechanic has left my local Vauxhall dealership!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No it won't need reset and even if it did a simple battery disconnection would work
    S.Lanarkshire
    Thanks very much John that's what I wanted to hear. I'll update this tomorrow.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Hopefully its just the plug, if the wire is damaged then it's quite possibly a new hub. The wires can be repaired but it's not easy!!
    Good luck.....
    S.Lanarkshire
    Problem solved. One of the ABS plugs wasn't in right. Lights also out on dash. Happy days.
    Glasgow
    Good result mate, the best fixes are the free ones lol.
  1. Lowering springs
    By paulvectrac in forum Handling & Braking
    Last Post: 14th October 2011, 16:45
  2. Lowering springs
    By rob10 in forum Handling & Braking
    Last Post: 8th October 2011, 18:24
  3. anyone used these lowering springs
    By 6009tristanb in forum Handling & Braking
    Last Post: 4th August 2011, 14:52
  4. Finished!!! x4 Eibach lowering springs fitted....
    By omega63 in forum Handling & Braking
    Last Post: 4th September 2010, 21:39
  5. Lowering springs
    By cbl1985 in forum Handling & Braking
    Last Post: 4th February 2010, 16:36
