Thread: signum 3.0v6 problem
    Aug 2011
    droitwich
    Default signum 3.0v6 problem
    think my water pump has gone?? i noticed some water under the car an when i poped the bonnet it was comein from the header tank. the heaters are stone cold and there is no water returning to the header tank. has any one had this problem?? only had the car 2 days. and wot other problems can i expect with the car?? thanks
    Private sale...?
    Aug 2011
    droitwich
    took it in part ex at work so i brought it at a bargain price. fully loaded with full service history and 80k on the clock and full vaxhall bodykit. nice car
    Bristol
    Hi the water under the car might be from the air con. The header tank flow will not take place until engine is at normal operating temp. make sure the cap is on correctly I had this and the cap was lose. The water pump is in timing gear housing if it leakes it will put water in the sump no on the floor. Also it takes a long time for the car to get warm, for the heaters to get hot it usually take 15 mins of normal driving or 1/2 on tickover.
    Aug 2011
    droitwich
    i drove the car for 10 miles an the heaters still dont get hot. the water in the header tank boils and comes out the over flow.
    Bristol
    I would change the thermostate first. That the cheapest option that will stop flow. A waterpump is about £170 and you have to remove the cambelt cover remove timing gears and then take the front cover of the engine to get to the waterpump. if you do that I would change the timing belt and rollers at the same time. I have never heard of waterpump failure on a V6cdti I have 2 of them.
    Quote Originally Posted by escoskmv View Post
    Do my dip and taste test to confirm whether it is fresh water or coolant
    As above, if you have been running the car with the air conditioning off, then as you park the car fresh water can continue to be expelled for some time and make it look like a leak
    Simply dipping your finger in and then tasting it will confirm which it is
    Equally, if the coolant system has failed the coolant level will be all over the place
    On starting the engine the coolant level should fall, resulting in the warning message appearing
    Once the engine has warmed this message should disappear
    On switching the engine off you should then be able to hear gurgling noises from the coolant bottle and possibly even see it boiling
    If that is the case, then I have a test for that, but perform the dip and taste first
  1. Signum 2.0T Problem
    By bigjohn1969 in forum Engine & Drivetrain
    Last Post: 20th October 2012, 13:12
  2. Rear Signum Light problem problem - help
  3. signum with a problem
    By frazer149 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2010, 23:53
  4. signum 2.2 dti problem, help please?
    By davidoverson in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 11:47
  5. Bit of problem with my new signum
    By N22CK_C in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2009, 16:07
