Thread: starting prob
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Default starting prob
    My veccie has a problem of starting when cold, it just goes brrrrrrrrrrrrrrrrrrr before starting, then once started, car is ok again! Can't be glowplugs, its 16 celcius outside and plugs only heat below 12
    Any ideas?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my 56 cdti sometimes only starts second time and makes funny noises and ive changed the glow plugs witch made no difference i will next have a look at the throttle body i dont want to buy a new starter although i think some vectras suffered with week starter motors. what engine is yours.
    morecambe
    32 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I think the plugs heat below 5 mate
    Jun 2011
    belgium
    Quote Originally Posted by paulvectrac View Post
    Ah I'm not sure, but had a talk to a friend of mine which is a vx-dealer and he said that you could search the tech 2 and there it will say below 12 degrees celcius glowplugs are active
    And mine is a 1.9cdti 120
    I guess I will have to remove the throttle body to, is it a lot of work?
    Jun 2011
    belgium
    Quote Originally Posted by dan danz View Post
    however when its freezing your socks of it starts perfectly
    west lothian
    Ok
    I have a 1.9 8v 120
    It was becomming a problem to start in a morning or when cold
    once started and run you could stop and start it all day
    I found it was the EGR valve that was stuck open causing the problem
    Replaced it and it started 1st time every time
    Jun 2011
    belgium
    Quote Originally Posted by p1aceb0 View Post
    Ok
    I have a 1.9 8v 120
    hmmm interesting, just cleaned the egr about 1month ago, and solenoid was working quite well but car does stutter a little so might be egr afterall
  1. starting prob?
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2013, 17:55
  2. vectra 1.9cdti starting prob
    By dickyblade in forum Troubleshooting
    Last Post: 15th August 2011, 10:29
  3. 2.2dti starting prob
    By sigtim in forum Engine & Drivetrain
    Last Post: 8th August 2011, 19:06
  4. My new vectra Starting prob
    By Vectra King in forum Engine & Drivetrain
    Last Post: 1st August 2010, 20:05
  5. ABS ecu prob
    By CBag7 in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2009, 13:12
