Results 1 to 10 of 22
Thread: cd 70 delay
    kirriemuir
    Default cd 70 delay
    hi fitted a cd 70 and colour display, put the areil in the hole on the dash but what i,ve noticed is a delay when passing the road ends with the display not quite so bad when scale is set to 250 yards and when its counting down with the bar at the side i,m at the turn off before its at the last block. i,ve treid 2007/8 and 2009/10 and 2010/11 discs the best being the last one the same when the voice tells you to turn usually right along side the turn and sometimes about 2 metres past it, are all the same ?
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    i would guess you may need to relocate your gps antennae so it can better signal
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    kirriemuir
    i thought in the midle of the dash would be the best place it connects in about a minute
    Jun 2009
    South Coast
    6 Post(s)
    some have fed them through to nearer the wheel arch to get a better signal..
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i have just paid £40 for the head unit and colour display from the local scrap yard with code just hope it works when i fit it
    kirriemuir
    40 a bargin if it works
    Jun 2009
    South Coast
    6 Post(s)
    are you using a Fakra antennae?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it takes time to learn the first time.. up to 50 miles.. it will become more and more acurate..
    kirriemuir
    oh right thanks kemp
    kirriemuir
    found out the problem the second gps antena has just packed up getting a signal then losing it and when i put my hand over it when locked its away again this is what i,ve ordered is it ok http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:L:OC:GB:1123
  1. lights on delay
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 19:53
  2. lights on delay
    By m8wos in forum Styling
    Last Post: 23rd October 2008, 20:43
  3. Trunk delay
    By lucasss in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 23:46
  4. Tuning box..........delay
    By diesel dog in forum Diesel Engine related
    Last Post: 6th July 2007, 00:03
  5. ECC air conditioning delay
    By stevedee3 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 11:43
