Results 1 to 10 of 15
Thread: po170 dode what does it mean
    Aug 2011
    sheffield
    Angry po170 dode what does it mean
    had car checked today and its coming up with fault code p0170 nothing else thing is now its running really bad on tick over sounds like its only running on 3 cylinders is a 1.8 2002 vectra sxi , any ideas anyone
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    http://lmgtfy.com/?q=vectra+fault+p0170
    P0170 Fuel Trim Bank 1
    I had exactly the same problem code coming up on my 2002 1.8LS (Z18XE), and it turned out to be the EGR valve in my instance. That's not to say it will be that in your case mind you:
    http://www.vectra-c.com/forum/showthread.php?t=103098
    Other than that, I would suggest looking for any air leaks, then possibly trying the MAF (Mass Air Flow) or the Lambda sensors.
    Aug 2011
    sheffield
    hi thanks tried all the above except the lamra sencor , changed the maf and coilpack cleaned the throttlebody ,thats when my problem started after cleaning the throttlebody
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    If it was fine before you done that, surely it sounds like a case of retracing your steps and checking all the connections you disturbed, both electrical or pipes/hoses?
    Aug 2011
    sheffield
    i i did read your post earlier and it is the same as mine , how is yours running now ?
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Since taking the EGR off and giving it a really good clean with carb cleaner, it's been absolutely spot on.
    Used to run really poor when cold for a mile or so, chuggy and spluttery, but it's perfect now.
    Aug 2011
    sheffield
    done that twic now lol been to garage they scratching there heads it use to struggle in a morning like yours going to try the brakecleaner check of spraying around the base of the egr
    Aug 2011
    sheffield
    just wondering if its the inside bit as i didnt go the that extream or maybe just buy another one , the garage was on about plugging it in and rading the live feed or something from it ?
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    My understanding is the the EGR valve was completely deleted from later models due to it being such a troublesome item.
    If you hunt about on here you will see that plenty of folk actually remove them from the earlier models and just blank the port off completely.
    Problem being it will bring on the EML if you just ditch the EGR completely, so I think some folk actually just leave it connected to the loom and ty-wrap it to something.
    Aug 2011
    sheffield
    got to be worth a shot have read problems with the maf , coilpack and the egr , i just get the feeling it something simple but i cant find it , the engine is really clean its going to be the death of me this car , the wife make sure of that lol
  1. 1.8 Z18xe PO170
    By VECTRAMAN in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2012, 13:15
po170 1.8 Vectra
