Thread: Ecu Connections
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Ecu Connections
    just a quick one guys
    on my 2.8 signum
    is it possible to unplug my 2 ECU connections in the engine compartment at the back of the engine
    to get to a pipe underneath ?
    or will the ECU reset ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Disconnect the battery first so as not to spike the ecu
    Mar 2011
    Northamptonshire
    do i have to disconnect the battery
    surely that will reset the ECU anyway
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just diss the battery mate then the ecu they are self learning so it will be fine
    Bristol
    tech 2 is the only way to reset ecu. or op-com etc etc. The only thing happen when you disconnect battery is it resets any fault codes stored. if it a facelift you will not have to put code in for radio, if it pre facelift you will. everything else will be fine.
  1. CID connections
    By samarkh in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2009, 17:26
  2. What connections...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 13:33
  3. BSR PPC connections?
    By FiscusFish in forum Diesel Engine related
    Last Post: 30th April 2008, 15:33
  4. ISO connections
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 00:21
  5. PS3 Connections?
    By Stevel in forum Games Room
    Last Post: 9th December 2007, 22:57
