Thread: Brake Lights on All Time
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    Default Brake Lights on All Time
    Tonight - cruise control de activated on motorway and Check Brake switch popped up on multi function display.
    Brake lights are now on all the time. I suspect that it is the switch that is activated by the brake pedal which is faulty.
    I have disconnected the wire to the switch, but the lights are still on. Then removed the fuse (F6 according to my manual) on the front passenger side fuse box. But the lights are still on.
    Lost patience with it tonight, so taken the brake light bulbs out of the ns and os but the boot brake light is still on - hoping it will still have a battery charge in the morning.
    Any ideas for me to try in the morning.
    It is an 07 1.9cdti elite.
    thanks Martin
    Regular Member bigdave1701's Avatar
    York
    Brake lights being permanently on is a sign of damage to the wiring loom usually caused by hot wiring a car. youve not been trying to nick your own car have you?
    Blantyre
    edit
    Sep 2009
    Glasgow
    brake switch sticking ?
    Sep 2010
    west sussex
    not an expert on this sort of thing, but this might help..I had a Xreg vectra,brake lights on all time...took vaux stealers 2 weeks to find fault...result was the brake servo was leaking, which was alowing brake pedal to drop very slightly which in turn activated brake light switch, so brake lights on all time...hth
    Oct 2007
    Leeds
    Going to try and replace the brake light switch as that was what the car reported was at fault first. Hope that works can't understand why the lights are stopping on with the fuse taken out.
    Anyone any idea how to remove the brake switch, can't see any obvious way to get it out.
    Martin
    Oct 2007
    Leeds
    Replaced the brake light switch which the car reported was the fault. disconnected the battery for half an hour. But still the brake lights are on!!!!
    So do we think it is a bad earth - really struggling - any help would be great.
    Martin
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake wearing in time
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2009, 11:08
  3. Brake lights on full time!
    By Dean82 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2008, 14:02
  4. Time for a Brake!!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2006, 09:27
signum brake lights on all time
vectra c brake light switch fault
