Thread: rev counter, speedo problem
    Aug 2009
    on the hills
    Default rev counter, speedo problem
    this is a teaser for you fellas, what could cause this to occur intermittantly?
    start the car, no problems then after about 10 mins the rev counter, speedo, fuel gauge and temp gauge all go to a zero reading as if the ignition is off, no other problem with anything else, the car still runs fine, radio works as do the lights. put the code reader on and no fault showing, disconnected the battery for 1/2 hour made no difference either, still does it, any ideas cheers keith.
    Apr 2011
    Toulon, France
    I do believe it could be a sim/cim problem, going off what I have seen on here in the past
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Recently had a similair issue...
    http://www.vectra-c.com/forum/showthread.php?t=143122
    Turned out to be the dashboard itslef not the CIM, but i was convinced it was the CIM. Not cheap, had to get by using a GPS speedo for my phone for a while and play "how full was my tank?" all the time.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by victorM View Post
    how old is the car ? ...if it is a early car has it had the abs plug mod done ? if a later car i would say dash easy way to see if it si the dash on a later car disconect the battery when it is off and see if it come straight back on when you reconect the battery
    Aug 2009
    on the hills
    its an 02 plate, i don`t know if any mod to the abs plug`s been done, any way to find out? cheers
    north east
    have a look in the How to section for cim / cluster problems there is approx 5 / 6 things you can check to fix this (hopefully)
    Aug 2009
    on the hills
    cheers roswell, found the thread, nice little job for the weekend, thanks again keith.
  1. LED Conversions on Speedo and Rev Counter Pics?
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 15:47
  2. Speedo and rev counter stopped working ??
    By Knuckle in forum Troubleshooting
    Last Post: 11th June 2011, 16:59
  3. Speedo / Rev counter etc
    By AngryDog in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 01:30
  4. speedo and rev counter eratic
    By johnrolfe in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2008, 19:22
  5. Dead speedo and rev counter
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 00:18
rev counter problem vectra
