Thread: URGENT Rear spring size
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default URGENT Rear spring size
    I got a set of klein springs delivered tuesday, went to fit them last night, and there quite a bit shorter than the ones that I took out, the ones delivered are 258mm, but I estimate the ones I have on now are close to 300mm. (forgot to measure them before I put it back in as I was in a hurry to pick the wife up from work)
    Does anyone know what size they should be. as I do not know if the springs I have in at the moment are even GM ones...
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    dont the klein springs give a 40mm drop? (sure that was mentioned on here before). So that would be about correct
    Oct 2010
    Walkden, Manchester
    I'm not to sure pal, they were stated as standard replacement (non lowering)
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Oct 2010
    Walkden, Manchester
    Not good, need to find out for sure what size springs I have fitted now, just hope it don't rain between now and 5 tonight..
    Jul 2009
    The Rift, Cardiff
    The amount of compression when fitted may be a factor.
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by ChrisBilly View Post
    Best thing to do (may take time) is on the rear measure the top of the wheel arch to the floor when car is on normal springs, then change out for the new springs and again measure the same distance. That will tell you what the difference is.
    If you've got all four springs then as long as you don't mind a low rider it'll be fine.
    Oct 2007
    nottingham
    fitted some KYB rear springs on my dti,exactly same as yours so measured wheel arch gap before and after,amazing but got exact same measurement with shorter new springs fitted.
    tommy
  1. 1.9 CDTI Front Spring Wanted Urgent!
    By yates in forum North East RO Vacant - ARO - Vacant
    Last Post: 11th November 2012, 18:56
  2. Tyre size for 19" Snowflakes - URGENT!
    By e55ex_rob in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2012, 10:42
  3. Urgent help... new coil springs wrong size
    Last Post: 9th June 2010, 22:41
  4. 2.2DTi brake disc size upgrade and shock and spring replacement
    By Mogsy007 in forum Handling & Braking
    Last Post: 14th February 2010, 13:25
vauxhall vectra c spring dimensions
best spring size for opel vectra c
