Results 1 to 10 of 19
Thread: Boarding out the loft...
    spoons
    Guest
    Default Boarding out the loft...
    Following on from my loft insulation project http://www.vectra-c.com/forum/showthread.php?t=144509
    It clearly states in the instructions that the insulation must be 'fluffed' out to gain maximum thermal insulation.
    It states that it must not be crushed or squashed down as this reduces thermal insulation significantly. In fact its recommended you have at least 270mm (10.5 inches) ideally.
    So if its not supposed to be crushed, what do people do if you want to board out the loft? for storage or another room?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    one would have to increase the size of the roof joists ,
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    What soulman said
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    if you want to board a loft or make an extra bedroom and flattening the fluffiness of you insulation roll , drastically reduces thermal insulation ,
    ( i'm not 100 % technichally sure ) ,,, but isn't there something with a shiny silver lining to put in you walls , under tiles or floor that helps .
    Maybe the shiny silverness reflects heat or helps retain heat or something ,
    it's just a distant memory , so i appologise if i'm wrong .
    Good luck with your project .
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    A matter of choice, do you want to save money on your heating or board the loft? Personally I have always boarded the loft just to make storing junk so much easier. Couldn't be bothered to increase the size of the roof joists.
    Mar 2011
    Quote Originally Posted by soulman View Post
    Good idea if it's for storage ,
    but would lose head hight in a bedroom in the loft , unless you get dorma windows added .
    Mar 2011
    Quote Originally Posted by MalcGSI View Post
    BUt isn't boarding the loft , just like adding another layer of resistance to keep losing the heat from the house ,
    it can only help , even if just a little .
    Regular Member s31num's Avatar
    May 2011
    were ever life takes me
    rolleyes
    Get some 4x2 then lay across joists to extend the space for. Insulation then board on top ,if you wana do it proper then remove top layer of insulation and lay new joists opisit way from old staggered 600mm apart then relay second layer in between new joists then board ,oh aye few dwangs in between new joists for strengh ,hth
    spoons
    Guest
    I just throw my junk out.. or sell it. No point storing stuff I dont want or need.
    spoons
    Guest
    Quote Originally Posted by s31num View Post
    Thats the answer then Thanks
  1. Loft Conversions
    By Brocks in forum General Chat
    Last Post: 13th August 2012, 19:26
  2. Sheep in my loft..
    By spoons in forum General Chat
    Last Post: 18th August 2011, 16:53
  3. anyone else got a Vectra Growing in the Loft??
    By redraptor_141 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 01:51
  4. Loft Insulation Bargain
    By Gregg in forum General Chat
    Last Post: 17th February 2009, 17:10
  5. Loft insulation and storage
    By JuzzyD in forum General Chat
    Last Post: 27th January 2007, 00:23
