Thread: i can't locate the power steering fluid
    Aug 2011
    oxford
    Default i can't locate the power steering fluid
    I have a 52-reg(25th/10/2011) vectra 1.8 elegance 16v. My power steering light has come on on the dash and also been shown as "please check the power steering fluid level" on the on-board computer, I wanted to top up the P/S fluid, but could not locate it under the bonnet.
    Could anyone tell me where the power steering fluid is located. any example photos? as that will be easy to find it out.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Behind the driver's side of the front bumper (under the wing)
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    iirc, easiest way is unscrew the wheel arch liner.
    Aug 2011
    oxford
    what does it look like? any photos?
    Feb 2011
    Selby
    On the 1.8 it's on the steering rack, behind the engine. The larger engines have less room there, so it's relocated to the front. The Haynes manual shows it nicely - so pop into a book shop or Halfords and have a sneaky look
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Some 1.8's are in the inside the front wheel arch and some are on the steering rack behind the engine, just below the brake fluid reservoir, its just a matter of looking. Easiest is the one to find is behind the engine, white bottle with a black cap.
    Feb 2011
    Selby
    Make sure you use the proper fluid from Vauxhall, it's not the generic red ATF that older power steering systems use.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have topped up mine before (2.2 dti). Not that hard. Just remove the wheel and undo the three lower torx screws in the arch liner. Pull it forward and reach in to unscrew the cap (green bottle). Then remove the filter from in the top of the bottle. I then lowered a length of hose pipe in from the top (bonnet open), and poured the fluid down this (use a funnel), to top it up. Difficult to see the level, so just do a bit at a time, and feel in the bottle neck for the fluid at the MAX line.
    HTH
  1. power steering fluid
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 09:46
  2. Power Steering Fluid
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  3. Power Steering fluid
    By Dazbaz in forum Engine & Drivetrain
    Last Post: 21st August 2009, 17:03
  4. power steering fluid
    By madp06 in forum Engine & Drivetrain
    Last Post: 13th February 2009, 11:40
  5. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
vectra c power steering fluid
https:www.vectra-c.comforumshowthread.php145095-i-can-t-locate-the-power-steering-fluid
vectra power steering fluid top up
vauxhall signum power steering fluid
vectra c power steering fluid bottle
where is power steering fluid located on vauxhall vectra
insignia 1.8 power steering fluid
08 vectra power steering fluid top up.
2007 vauxhall vectra power steering fluid
power steering fluid vectra c
steering fluid level opel vectra
how to put power steering oil in vauxhall zafira 2010
97 opel vectra power steering fluid location
power steering reservoir vauxhall vectra
power steering reservoir vectra c
where is the power steering fluid on a vauxhall meriva
vectra c 03 power steering fluid
power steering fluid vectra c 1.9 diesel
vauxhall zafira power steering fluid reservoir
how to top up power steering fluid holden vectra
how to top up power steering fluid vauxhall zafira
vectra c how to check power steering fluid
power steering fluid vectra 2003
