Thread: Gear Knob is loose
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Gear Knob is loose
    Guys my gear knob is loose and i need to tighten it any ideas?it is just the top part as it will push down and you can hear it clicking and its very annoying. It isnt the stick or anything else just the knob part. (oh what a double meaning post this could look like!) please help
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Mine was like that. (mate who borrowed the car then tried to screw it back on when it popped off.... Which basically removed any thread left on the inside of the knob) Unfortunately there isn't a GM part number JUST for the gear knob. So you have to buy the whole stick, I ended up resorting to an irmscher knob.
    Purely because I didn't want to risk fouling the reverse spring with glue that might seep down when trying to stick it back together.
    Aug 2007
    Lisburn, N.Ireland
    so its starting to come off then? any idea of the part number and cost? Is it hard to change?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i think these are very dear in the dealers , you would be best to try the breakers for 1
    Best thing to do is remove it by pulling it up sharply , make sure you don't lose the spring underneath it
    Cut a small piece of cloth from say an old pillow case about 1cm x 1 cm
    Place the cloth on top of the stick piece
    Replace the spring
    Place the gear knob back on the stick
    Then give it a sharp smack down wards with your palm
    If that doesn't locate it properly them cover the top of the gear knob in an old towel and tap gently with a plastic or rubber mallet
    Hope this helps
    Sodding Typical on Sea
    Some people will glue them back on with a suitable liquid metal epoxy but more often than not, others will go for a Richbrook or Irmscher knob.
    The entire lever (as also mentioned above) was replaced in my Vectra before I bought it for this reason, the result was a lovely tight gearshift patterns
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Yep, the gear knob is a disaster. I used some cloths, matches, tissues and finally one mechanic put some glue underneath. After one year it starts to come off again and I still have no concrete idea...
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Quote Originally Posted by marktaylor View Post
    Replace the spring
    Hope this helps
    Exactly what i done and its still their, the best option imo
    Aug 2007
    Lisburn, N.Ireland
    glad im not the only one lol. So just a really sharp pull up then releases it then?!
    Regular Member irmscher72's Avatar
    northants
    Pull it up sharply, but as MarkTaylor said watch the spring as it does fly out, then just glue it back down, happened on mine a good year ago, was gonna get a six speed one from Irmscher but said they don't make em any more, hasn't come off since HTH !!!!!!!
  1. gear selector come loose
    By nelly452 in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 21:55
  2. Gear Knob loose?
    By lencuff in forum Bodywork & Interior
    Last Post: 7th June 2011, 22:59
  3. gear stick loose
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 7th June 2011, 22:33
  4. loose gear knob
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 21:42
  5. Loose Gear Knob
    By phil67 in forum Bodywork & Interior
    Last Post: 31st July 2009, 08:11
loose gear knob Vauxhall vectra 2006
loose vauxhall gear knob
