Results 1 to 3 of 3
Thread: how do i know if my timing is out???
    Jun 2011
    machynlleth powys
    Default how do i know if my timing is out???
    hi all how would i know if my timing is out on my 1.9 cdti what symptoms would i have ???
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    On your CDTi? I just read the first bit and thought "when you get your face slapped".
    Thought the timing was all set and sensor monitored/ controlled, unless the belt breaks or slips? What makes you think it is?
    Jun 2011
    machynlleth powys
    engine has recently had all injectors tested one replaced and coded . flywheel and cluch . fuel pump . intercooler . long list i know but now the car has started vibrating while driving very bad at times and while the car is ideling it sounds like its missfireing put your foot down and it will make a rattle diesel knock apparently thats as much info i can give you the power is there it pulls like a train .
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing on dti
    By kman247 in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 20:44
  3. Timing.
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 12:48
  4. Two Timing Git, lol
    By VauxVeteran in forum General Chat
    Last Post: 12th June 2007, 17:40
