Results 1 to 3 of 3
Thread: Help with installing a nokia ck-7 car kit
    Regular Member j6onn's Avatar
    swindon, uk
    Default Help with installing a nokia ck-7 car kit
    Hello peeps, can someone please help? Im going to install a nokia ck-7 hands free kit through my cdr 2005 and im unsure which wires i need to splice into so i can use the mute function and have the calls through the car speakers. Someone has said i need to connect the mute to pin 13 and then the audio+ into pin 16 and audio neg into pin 19. Also someone put a diagram on here showing the correct pins as c3,a3 and c8 which has confused me a little??? Also am i right to cut the lead from the external speaker and use as audio in???
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Normally most members on here use the SOT122s adaptor cables/connector
    Full Member
    Bristol
    If you look behind the radio in behind the glove compartment there are wires labeled up already. If you have a latest blackberry phone with latest software it will no work with this kit.
  1. Help installing Nokia ck-200 into Signum with CCR2006
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 20:30
  2. installing handsfree (Nokia CW-7k)
    By macwillis in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2012, 21:21
  3. Installing a sat nav
    By mattyj33 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2009, 10:18
  4. Installing Sat Nav....
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 18:58
