Results 1 to 10 of 17
Thread: Another quick parking sensor wire question
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Default Another quick parking sensor wire question
    So , after reading up on how to power up the after market parking kit im a little confused on a couple of things , if i can plug you for advice & help.
    To connect the power lead to the reverse light live : so on a vectra can anyone enhance on this a touch , scotch lock yes ...what colour wire etc pics if poss.
    Secondly ... well ... nope that's pretty much it really , its just the fact ive read so many things my heads hurting with all different opinions on overall fitting.
    thanks in advance.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I not sure what wire. But personally wouldn't use scotch locks. Better to solder the wire
    Regular Member rockonoli1's Avatar
    Telford
    Don't you also have to use a bypass relay to cancel out bulb failure warning ? I have read this on a couple of other threads and also asked the question elsewhere but had no answer.
    Jul 2009
    The Rift, Cardiff
    The reverse light wire is white/black (white with black trace). As said it would be much better to solder the connection. For the earth you could use the brown wire in for the light cluster or direct to the body, plenty of choice iirc.
    No need for a relay, the sensors don't cause an error and the bulb check pulse isn't enough to trigger the sensors.
    Regular Member Zark's Avatar
    Herts
    While this thread's here... it stops me making a new one!
    4 parking sensors fitted in rear - 2 in front bumper.
    Control box in the boot... fed from a switched live from under the cigarette lighter. Earthed to bodywork nearby.
    Rears are fine... fed from reversing light wire does everything i hoped.
    The instructions said to wire the fronts into the brake light switch... so when brakes on - fronts are activated.
    I didn't want them on all the time - so i broke into the brakelight feed wire and took two cables up to a simple illuminated switch in the dash... The switch has 3 pins. 12v in, 12v out and ground... no light wire... the LED (should) simply come on when the switch is on
    Brakelight---------------switch--------------control box
    Easy, i thought... sensors only live with ignition on - rears controlled by reverse light and fronts by brake lights....
    Now is where my expertise starts to run out!
    Ignition on... switch for fronts off.... the LED in the switch pulses every few seconds... I presume the bulb check sends a signal every few seconds? Anyway - i don't get a bulb fail error (because the bulb's OK!)
    But - every time i press brake pedal - the switch LED comes on, and then goes off. No beeps or anything so sensors not active.
    Ignition on switch on... press brake pedal and sensors work... park as close to wall as i dare and all's fine. Handbrake on - foot OFF the brake... sensors still beeeeeeeeeeep!!!! Aaaargh! Make it stop... Turn switch off.... No still beeping!!!! Engage reverse, then nuetral... phew!!! Noise has stopped. Which is OK if parking, but if i'm in traffic or something - the beep continues until the car in front moves off again... At a level crossing - that may be some considerable time!
    And when driving at night... lights on... the LED on switch is on regardless of the position it's in, though gets brighter under braking.... I'm guessing a dual filament bulb? So have i tapped into the right wire in the cluster - or would it not make a difference?
    I'm guessing i need a different type of switch? But which one... or i need to separate a signal from the brake light to activate the sensors? Like some sort of relay?
    Any advice...? I want the switch to properly isolate the front sensors (so i don't want to put a switch in the live feed to the control box- as that would affect the rears too?) i want the switch to turn on and off the signal from the brake light to the control box.... so i can drive without the fronts on when i don't need them.
    I can't link to them from here - but i got a 6 sensor kit off the bay of E... with the led dash display, about £25... and the switch is a 12v illuminated cheapy from ebay too.
    Regular Member Deann's Avatar
    Mar 2011
    England
    I've jsut bought some aprking sensors...
    So the Red Wire Live in my kit is scotch connected to the black/white wire in the rear light cluster
    and the Black wire in my kit is scotch connected onto the brown earth wire in my rear light cluster?
    Herts
    Yeah probably... I just made mine extra complicated!
    I test fitted the rears connecting the control box live and the sensor wire both into the reverse light feed and put a ring crimp connector on the end of the earth, and put it onto a nearby bolt... worked fine
    cheshire
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Fantastic stuff !!
    Looks like ill be aiming for the live onto the black/white reverse wire then & the earth to the chasis , ill have a good ole rummage around to find the best earth !
    Im certainly not going to rush the job ... ill make a day of it mon or tues when the spray can arrives for "lightning silver "
    Mar 2011
    England
    Just fitted my sensors... so easy to do... removed the back bumper and everything works fine
    + black and white wire
    Earth brown wire
    newport
    did you trail the beeper through to the front or leave it in the back somewhere? thinking of doing this, but dont want a distracting drowning beeper like we had with the vw, something subtle would be better
  1. VXR bumper & Parking sensor question
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2012, 13:10
  2. parking sensor question
    By stuthevaux in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2011, 19:49
  3. Parking sensor - which wire is reverse?
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 22:41
  4. Rear parking sensor question
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 17:46
  5. Quick 'Which Wire' Question...
    By chrisschild in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2008, 10:00
how to wire parking sensors the ignition wire vauxhall vectra
