Results 1 to 10 of 13
Thread: caliper carrier bolts
    Regular Member trickyjacks.4's Avatar
    nottingham
    Default caliper carrier bolts
    Is it essential to replace the caliper carrier bolts when replacing the rear discs, it says in the how to that you have to use new bolts but I have just spoken to the parts guy at my local stealers and he says new bolts aren't needed.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i refitted my old ones with no issues
    nottingham
    cheers for the info, right better get my tools out.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    9 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 207,200
    I'm going to do my discs and pads soon. Probably the weekend after next. I plan to get new bolts but it depends how much the stealer wants. When I find out, I'll post the price.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member hagga's Avatar
    kingswinford
    Using new bolts is only recommended due to them being precoated with threadlock... use the old bolts with a lil loctite or something similar and all is good... once had mot fail me for a brake issue..changed caliper and returned, then he was then going to fail me for using same bolts until I produced a bottle of threadlock out the boot.
    Same question was asked just recently.
    http://www.vectra-c.com/forum/showthread.php?t=144793
    and no, you can use the old ones once cleaned up.
    Regular Member Danger_MouseUK's Avatar
    Jan 2010
    Merseyside
    Just cleaned and reused mine with some locktite on... tho thanks to the rain I only got one side done. I hope it's dry tomorrow morning so i can do the other side lol :s
    nottingham
    Thanks for all the replies fellas changed the rear discs and pads this evening using the old bolts and some threadlock, done about 20 miles tonight and all is still tight.
    cheers
    Sean.
    9 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 207,200
    Ok. So I guess it is okay to reuse existing bolts. I'll save precious pennies, then. I have Loctite (three different strengths) in the garage.
    One poster in the other thread said he used Coppaslip in reassembly to keep the water out. Is that okay? I mean, the caliper mounting bolts are torqued up to a huge figure already, so shouldn't work loose. Any thoughts?
    Paul
    Copperslip will make the bolts do up easier - and in doing so you risk over tightening the bolts.
    Loctite would be the best and recommended solution.
  1. caliper carrier bolts
    By maximus1267 in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2016, 16:39
  2. Caliper carrier bolts - still can't get them
    By shchuka in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2012, 14:45
  3. Where to get caliper carrier bolts?
    By shchuka in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2012, 22:01
  4. Nightmare trying to remove the rear caliper carrier bolts!!
    By richiem in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2011, 01:10
  5. Replacing Brake Discs - new caliper carrier bolts?
    By markconlen in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2008, 23:32
