Results 1 to 10 of 25
Thread: tailgate auto-close issue
    milan
    Default tailgate auto-close issue
    Hi guys,
    I'm currently having issue with the automatic closure my vectra c 2007 tailgate,
    actually the tailgate opens properly no issue there, but everytime I'm closing the tailgate it stops halfway without reason, it seems that it sense something underneath and it stops. After actioning the closing button a second time sometimes the tailsgate shut down, sometimes it doesn't thus I have to pressit several times before it works.
    Do you have any idea about it?I was thinking that it could be related to the action controlled mechanism which folds the tailgate itself.
    Could you help, please?
    Thanks a lot
    Msqualo
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    It's a very common problem and mine has just started doing the exact same too. It's usually part of the internals of the motor worn out. I plan to strip mine apart and re-grease and oil it all to see if that solves it although I'm not confident.
    milan
    Hi Ian,
    thanks,
    one question, do you know how to detach the cable which transmit the piston gear movement from the motor?
    Do you have a tech scheme or a drawing which explain your maintenace thoughts?
    Msqualo
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    Yes this is a common problem. Two times a have disassembled the hole unit without find any issue, when assembled again it have been okay for months. It may be the potentiometer that have an intermittent fail. The potentiometer are available as spare.
    Check this thread about retrofitting power tailgate it may help you.
    http://www.vectra-c.com/forum/showthread.php?t=121114
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it can be 2 things..
    The potentiometer..
    But also on the cabel, theres a "piece of white" plastic.. that moves forward/backwards, when it open/closes..
    That one also controls the motor.. as when is "at motor end" it hits a switch, that then stops the motor.. its a NON repair item.. if its that.. because you cant get a new wire on its own.
    Øvre Årdal, Norway
    Quote Originally Posted by kenp View Post
    The potentiometer..
    I'm sure what you mean, can't remember any mowing plastic parts except the cog wheels. It's a metal part that activate the internal micro switch.
    Do you have a picture from the inside.
    Mine stoped working again last Friday so I have to fix it again.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Engine : 2.2 Direct
    Ill take my spare motor apart .. its a plastic part, that moves the metal part that activate the internal micro switch..
    that plastic bit is around the wire.. and sits flush at the buttom, when the strut is NOT compressed..
    milan
    Dear All,
    could you please tell me were is the potentiometer(maybe a picture would help), I would also ask you if you could tell me how to dismount the motor from the cable which transmit the movement(an image would help)?
    In case, could you please let me know the potentiometer part number.
    Thank you all for your help in advance
    bye
    Msqualo
    Engine : 2.2 Direct
    here you go
    milan
    Thank you In case, could you please let me know the potentiometer part number
    bye
    Msqualo
  1. auto close windows
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 01:50
  2. Window auto close?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2011, 12:39
  3. Auto Tailgate
    By Ian Mac in forum Bodywork & Interior
    Last Post: 2nd June 2009, 14:38
  4. Auto-close boot problems
    By dave200 in forum Bodywork & Interior
    Last Post: 5th August 2008, 11:09
  5. Auto Close Windows If It Rains
    By Gordon B in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2008, 18:39
auto close tailgate
vectra auto tailgate calibration
