Thread: Wheel Nuts
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default Wheel Nuts
    Was thinkin before when talkin to Lee gsi can you use the standard alloy wheel nuts of standard Vx alloys and use them with after Market wheels the same pcd ofcorse
    Regular Member hagga's Avatar
    kingswinford
    there shouldn't be a problem but I always poke a bolt through the alloy and see how much thread pokes though... my personal limit is at least 'diameter of thread+2 threads'.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    So I should have the same amount of thread showing on bit wheels plus 2 extra threads showing on the after Market ones
    kingswinford
    Quote Originally Posted by paulvectrac View Post
    Sorry Paul..I think I've just given you the worst bit of advice ever what I should have said is 'dia of thread+brake disc thickness + 2 threads'..(sorry been working with wheel spacers too much of late where not had to concider disc).. but the general rule of nuts/threaded holes is that you want at least 2 threads protuding through... check the bolts with original/after market wheels.. if the exposed thread is equal to or more than on the aftermarket ones they'll be fine
    note to ones self...don't answer posts when i've had a beer or two lol
    11 Post(s)
    Don't also forget that the taper of the bolt might be different to that of the seating faces of holes in the alloy wheel.
    kingswinford
    If he's using the original 'alloy' bolts the taper will be the same... as far as I know they're all standard now....radius are radius, tapered are tapered.. they're not manufacture specific.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Me thinks I might go get some new wheel nut just in case
  1. Wheel Nuts
    By KSD in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 15:24
  2. wheel nuts
    By 06 vectra in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 16:36
  3. wheel nuts
    Last Post: 5th February 2008, 19:28
  4. wheel nuts help
    By surreyl31 in forum General Chat
    Last Post: 30th July 2007, 20:16
