Thread: Vectra c sri leather seat fitment help?
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default Vectra c sri leather seat fitment help?
    Hi there
    i firstly would like to thank in advanced ..
    i have been offered a set of half leather seats from a vectra c 3.2 gsi 53 plate for £ 300 incl is pair front seats ,rear seats ,door cards ,centre armrest and trims . what i need to know is will these fit into a vectra c 2.0 turbo sri 08 plate without any issues involved ie wiring under seats ,fixing position etc . also will i get any issues with any lights suddenly appearing on the dash as i disconnect the old seats . ? cheers again mark .
    Regular Member bish's Avatar
    peterborough cambs :P
    Hello fella, im the one selling the seats, whats the sri got in it, should have sports seats in it already with the larger bolsters etc, in cloth or half leather trim
    Aug 2007
    NORFOLK
    hi mate lol what a small world we live in today yer it has the standard sri seats in cloth . will they fit?
    scottish region
    They will fit I recommend you disconnect the battery and once fitted they will show an airbag fault which can be cleared with a good fault code reader
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Should fit mate. Just make sure you disconnect the battery
    Full Member
    South West
    Removed my original Sri seats and fitted elites, then changed again to Sri leathers.. Battery was never disconnected when I did mine, and on the first change the airbag light came on as the retainer clip on the seat plug snapped. As soon as it was replaced the light went out.
    Where as I did this without disconnecting the battery, if I was doing it again I probably would.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Changed loads of interiors and never disconnected the battery. The airbag light will only stay off if you fail to connect everything correctly. Once everything is correct the airbag light will go out without having to be reset or it has in all the times its happened to me
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by merikiito View Post
    As above, never had a light come up on mine , but battery disconection is probably a wise move
    Regular Member aps's Avatar
    cheshire
    Vehicle : Vectra C Sri CDti 150 (satnav)
    Trim : Sri
    Engine : 1.9cdti
    Year : 07
    Hmmmmmm.... this brings back memories ..
    Ive change 2 Ford Cougar interiors in my time & both times hit major issues !
    Im not saying it will be the case with VX but with the Cougar both times the wiring loom / connectors were totally different on both occasions ! i had to hard wire the first set in & the second set was different again , couldnt work it out at all so had to make do without some seat functions.
    Good luck anyhoo..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by aps View Post
    Good luck anyhoo..
    Thats what you get for owning a Ford. There are no problems as VX use the same plugs on all the Vectra c/Signums for seating.
  1. under seat sub fitment
    By m1ke823146 in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 21:20
  2. rear seat fitment 2002 hatchback
    By mustangboy in forum Bodywork & Interior
    Last Post: 22nd November 2009, 14:01
  3. leather seat fitment
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 13:21
  4. vectra c seat fitment?
    By matrix1979 in forum Bodywork & Interior
    Last Post: 28th August 2007, 21:11
vectra c sri interior
clube do Vectra fitment
https:www.vectra-c.comforumshowthread.php145012-Vectra-c-sri-leather-seat-fitment-help
vectra c half leather interior
vectra c leather interior
half leather insignia sri seats wanted
vectra c leather dash
leather seats vectra c
