Results 1 to 10 of 22
Thread: oil catch tank
    Regular Member spidermonkey's Avatar
    Jun 2011
    mexborough
    Smile oil catch tank
    got my catch tank today and got it fitted straight away as i just got the car back from garage after having a new inlet manifold , timing belt and water pump fitted.Decided to fit the tank in a closed system loop first to see if it made any difference.
    Feb 2011
    London
    Looks tidy. Can you take some pictures of where you plumbed it to the car please. I plan to do it but am not sure on where to fit
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Where did you get it from? how much?
    Jun 2011
    mexborough
    it was off ebay for about £25
    Jun 2011
    mexborough
    pictures of my oil catch tank set up
    Feb 2011
    London
    thanks for the pics.
    Regular Member Innes's Avatar
    Plymouth
    Is that hose going to stand up to the heat of the engine?
    I've ordered a catch tank for my 2.2dti. I've also ordered some blue silicone hose so should stand up to the heat.
    How did you attach the bracket to the bulkhead? Did you just drill into it? I may put mine on the battery box as I was abit worried about drilling into the bulkhead and hitting something behind!
    Regular Member hagga's Avatar
    kingswinford
    you need to be careful that with the length of those hoses and the tank being higher that the vapour doesn't condense before getting to the tank and just runs back... maybe not an issue now but could cause probs in the winter if it freezes.
    Regular Member smokydiesel's Avatar
    barnsley
    Default catch tank
    hi this might be a silly question but the metal pie that runs over the engine don't you need to blank this of as it it will still be trying to suck crap into the turbo i know silly question and all but any ideas?
    Antwerp, Belgium
    i would like to see a setup on a 120 hp model
    anyone has done this mod on his 120?
  1. oil catch tank.
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2012, 00:32
  2. Oil catch tank
    Last Post: 23rd December 2011, 16:04
  3. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  4. oil catch tank
    By spidermonkey in forum Engine & Drivetrain
    Last Post: 16th August 2011, 14:40
  5. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
