Thread: Advice on Temp
    Aug 2010
    staffs
    Default Advice on Temp
    Hi all,
    I noticed the other day that while sat in traffic the temp crept up to 90, I know this is normal but it had never gone above 85/86 in the past in all driving conditions except winter.
    Tonight on my way home stuck in traffic it did the same,it hit 90 went over a bit, fan kicked in and went just below. It did this 2 or 3 times..
    Any one explain why its doing it all of a sudden...
    ta...
    2008 cdti 120
    could it be the dpf regen activating but in stationary traffic?????????????
    Aug 2010
    staffs
    forgot to mention that it still sits around 85 under normal driving conditions
    Perfectly normal mate - the airflow of driving usually keeps it around 85, and sitting stationary causes it to raise till it reaches the temp where the fan kicks in. Do you know if you definitely have a DPF...?
    Aug 2010
    staffs
    i uderstood that all cdti's had them after 2006, and it does explain the process in the handbook so i'm pretty sure it has
    Only the estates, autos and Signums. My 57 plate manual hatchback doesn't have one...
    Aug 2010
    staffs
    YEP,,,, got an estate
    That answers that one then...
    It may have been doing it then, but certainly nothing to worry about mate. Easiest way is to check the instantaneous consumption if you have that option on yours...
    Aug 2010
    Derbyshire
    Your temp seems to be acting normally, just like mine really. No worries.
    CDTi 150 Signum.
    Mick
  1. CID, Outside air temp
    By Ken072 in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2011, 22:23
  2. Outside air temp
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 21:54
  3. My new temp car
    By sberrow in forum Non Vectra C/Signum Album
    Last Post: 7th March 2010, 11:06
  4. temp
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2009, 13:52
  5. outside temp
    By willoftoon in forum The 'Off Topic' room
    Last Post: 10th August 2008, 19:49
