Thread: Vectra C towbar electrics help
    Jan 2010
    Yorkshire
    Default Vectra C towbar electrics help
    Hi
    I have just fitted a new towbar to my Vectra 1.8 petrol with twin electrics.
    I have also fitted a universal 7 way smart bypass relay AEU7R/TEB7AS and wired up as per instructions coupling to cars live and earth as described then scotchlocking into wires for rear lights L & R, indicators L & R, brake light, fog and reverse.
    Nothing works on caravan electrics when coupled up!
    When indicators are switched on there is audible noise from relays in boot but no lights work on caravan.
    I have also fitted a seperate relay AESSCR for the caravan fridge e.t.c. No power to that either!
    There is power to some of the relay connections when I put multmeter on
    HELP
    Thanks in advance
    Aug 2010
    Leeds
    If it was anything like the astra the fuse box in the boot had to be activated to get anything to work.
    Jan 2010
    Yorkshire
    How do I do that then?
    Everything ion the car still works fine. just no power to caravan
    May 2011
    bispham, blackpool
    when i had my car on my opcom i noticed it said towbar electrics and they were switched off so as i have a tow bar i switched them on but i havent towed anything yet so dont know if they worked or not before
    so i think they will need switching on by means of opcom or tech 2
    Jan 2010
    Yorkshire
    confused
    A trip to friendly Vaux dealers then?? may as well have let them fit the thing if thats the case
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Since you're using a AEU7R/TEB7AS relay box there's no need to get the Vectra Tech2'd or worry about its electrics at all. The relay system doesn't rely on the car's electronics.
    If the relays are clicking in time with the indicators there are only these possibilities:
    1. Not wired correctly to the caravan
    2. 12v battery feed not connected or not live. (The Ground must be OK or the relays wouldn't be clicking).
    3. Wiring, connectors or bulbs faulty on caravan.
    So I'd do the following:
    Make sure the caravan lighting is OK - best way is to check it out with someone elses car. Alternatively connect a battery to the various pins on the connector and check that the appropriate light comes on.
    If OK, check that the wiring from the relays to the car tow socket is correct. You say that it is but do it again.
    If OK check that the 12v feed from the car is OK. Don't use a meter because they give a reading even with a tiny amount of leakage current. Connect a test bulb from the 12v feed to chassis.
    If OK check that the connection from the caravan ground to the car chassis is sound. Use a test bulb from the 12v battery positive to the ground connection on the towing socket.
    If all of that checks out OK and still not working, turn 1 indicator on and use a test bulb on each output of the relay box to find which output is live then follow your nose.
    HTH
    Jan 2010
    Yorkshire
    Thanks a lot boba
    Ill check through that lot tomorrow and report back
    Jan 2010
    Yorkshire
    Smile
    Turns out when I checked all wiring and tested it all it was a poor earthing issue
    Thanks again for advice
  1. Vectra C towbar electrics/Relay wiring
    By canny03 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 01:31
  2. For Sale - Vectra Hatch Towbar and Electrics
    By AJA in forum Parts for sale
    Last Post: 3rd September 2007, 21:22
vauxhall vectra towbar electrics
can towbar be fitted to vectra c without 7 way relay
vauxhallvectra towbar electrics
vectra c towbar electrics
vectra c towbar wiring plug
vauxhall vectra c towbar electrics
vauxhall vectra teb7as fuse
vauxhall vectra teb7as wiring
towbar electrics vectra c
vectra towing electrics
