Thread: Sump bolt 2.2 DTi. Doing Oil change.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Default Sump bolt 2.2 DTi. Doing Oil change.
    Can anybody help me with a couple of questions as I'm changing my oil and filter at the weekend?
    1. Size of sump bolt. Is it recessed requiring a socket or will an adjustable spanner do the job?
    2. Is the sump bolt accessable without removing the plastic engine undertray?
    I'm using Valvoline SynPower fully synthetic 5W-40 oil. I've used this on my cars in the past and have had no problems. Its certified for VAG/BMW/Merc and Opel longlife service intervals so the 10k miles I do between changes should be no problem.
    Apologies for this thread being posted in the wrong section at first.
    Thanks.
    Ross.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Hi Ross
    1. use a Torx T45 to remove the sump plug
    2. you DO need to remove that silly plate thingy
    3. the oilfilter cartridge cap needs a 36mm socket to get it off
    HTH mate
    Steve
    Nicking Ya Dinner.
    Support the tray, it splits if you dont, hth.
    Oh and expect resistance from the sump bung, shock treatment is the most reliable method.
    Thanks for your help guys, its much appreciated!
  1. Replies: 9
    Last Post: 10th September 2012, 17:04
  2. Sump Plug - Oil Change
    By Sparky67 in forum Engine & Drivetrain
    Last Post: 25th March 2010, 21:43
  3. Sump bolt 2.2 DTi. Doing Oil change.
    By Ross DTi 2.2 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 12:18
  4. Sump Plug Bolt Advice
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 19:36
  5. Sump Drain Bolt
    By Dazzar in forum Engine & Drivetrain
    Last Post: 4th January 2007, 09:51
